The review
This is a multi media kit, with plastic, resin and PE. So starting with the frame, which is plastic, it goes together very well, no fit issues. Just note when assembling and glue to ensure it is square.
The frame stiffener plates are PE, the upper and lower plates for the mid cross piece need to be notched to fit.
When the frame is all together, it is very nicely detailed and looks great.
The axles fit onto the suspension with wire for the U-bolts, and it is much easier to cut wire leaving a little extra, and gluing one side in and letting it dry before bending and setting the other side in place. Also note it is easier to do before you mount onto the frame.
So onto the motor, it is cast in resin, and looks great. I added wire for the plug wires and fan belt.
I also put the front brake drums and transfer case together, again well detailed, too bad they will be hidden behind the wheels.
The only real issue I have had so far is following the instructions, as mentioned in the review they are not the usual diagram step, but images of the build sub-assemblies. I find myself going back and forth in the images as I progress.
Next steps are to complete the frame and motor sections before moving on to the body assembly.
