Hi every1!
What would be the right colour for Tiger "121"? Turret numbers on decalsheet are with white outline and transparent on center. Should it be dark yellow or maybe U.S. OD?
Colour of Tamiya DAK Tiger I?
casualmodeler
KitMaker: 702 posts
Armorama: 665 posts
Posted: Monday, February 25, 2013 - 06:50 AM UTC
Byrden
KitMaker: 2,233 posts
Armorama: 2,221 posts
Posted: Monday, February 25, 2013 - 08:23 AM UTC
I think this model Tiger has the right colours, but the wrong way around. The brown would be the base colour, inside the digits.
There are accuracy problems with the Tamiya Afrika Tiger.
David
David
didiumus
KitMaker: 564 posts
Armorama: 312 posts
Posted: Monday, February 25, 2013 - 03:54 PM UTC
I agree with David. You can find color photos of wrecked Tunisian Tigers that corroborate this, and also veterans of the Tunisian campaigns have also corroborated the "Green" color. It is clear from the BW photos that the tanks are not yellow. I think it is actually greenish-brown, one of the Troppen Scheme colors, or perhaps both of them. RAL 8000/8020 .
Hope this helps.
Scott Gentry
Hope this helps.
Scott Gentry
casualmodeler
KitMaker: 702 posts
Armorama: 665 posts
Posted: Monday, February 25, 2013 - 07:53 PM UTC
Thx guys!
I think I skip "121" from my options, mixing right colour or even close to it with Humbrol would be nerve cracking..
I think I'll stick with "731" or "813".
Byrden
Posted: Monday, February 25, 2013 - 09:05 PM UTC
Wat?
They're all the same!
David
David
casualmodeler
KitMaker: 702 posts
Armorama: 665 posts
Posted: Sunday, March 03, 2013 - 05:40 AM UTC
Sorry David
But didn't quite understand your reply..
But anyway, can someone tell the right colour for turret numbers of Pz.III Ausf.N of 501? I just boughed Tamiya Pz.III N and found some Tamiya AM decals back home and there was decals for "06" Pz.III Ausf.N. Problem is they were red/white but drawing on TiF shows them black/white..?
Byrden
Posted: Sunday, March 03, 2013 - 07:22 AM UTC
I mean, the same 2 camouflage colours were apparently used on all the Tigers of the unit. But I suppose you'll have an easier time with the red-filled digits.
David
David
casualmodeler
KitMaker: 702 posts
Armorama: 665 posts
Posted: Monday, March 11, 2013 - 08:51 AM UTC
Hi all!
This is not about the colour but how much or which parts from DML Initial Tiger I (6252) can be swap into Tamiya DAK Tiger I?? I boughed partially assembled DML kit and it's destiny will be spareparts donor. I mean, if parts are same size but DML is better detailed, I could use them in Tamiya?
didiumus
KitMaker: 564 posts
Armorama: 312 posts
Posted: Wednesday, March 13, 2013 - 02:10 AM UTC
A better way to go would be to use a Dragon kit as a base, and then add the specific Tunisian Tiger parts to it. I have done this with a Dragon Initial Tiger and it worked well. The Dragon parts tend to be much more accurate, but as you are well aware there are many different variants so you need to do your homework. And as always, which tank or unit do you want to model? The Tigers of 501rst PD in Tunisia were VERY different from the 504th PD Tigers.
Hope some of this is helpful.
Scott Gentry
Scott Gentry
Byrden
Posted: Wednesday, March 13, 2013 - 03:36 AM UTC
I can add that the Tigers within s.Pz.Abt. 501 had variations, and I would put them in 3 groups!
David
David
