I've been quite remiss in my duties to this blog showing my progress. But to be truthful, there hasn't been much to update as I've been tied up doing other things! I have some stuff to share today, though. First, I noticed that the plate I added to cover the missing close-in defense weapon was in the wrong place. So, I carved the old one off and punched out a new one and glued it to the top of the "open" turret. It still needs 4 bolts, but that will be for later:
Next, I gave the interior a coat of paint. So far, only the lower part of the turret, cupola and front plate have gotten this treatment. I used some Gunze "sail" colored paint, as it looked pretty pale in the jar. With the red-brown primer under it, it is darker. Oh well.
You can see here where I left the primer showing. I really agonized over this, but decided on this as the Germans decided on painting everything above the vehicle's fender-line with ivory paint, but left everything below that line in primer. I made a command decision to paint whatever equipment was bolted to the floor to painted ivory, too. It'll make the interior of the turret more interesting once it's closed up by showing different colors in the gloom.
Here's the back of the front plate. It's got a ton of knock-out pin marks, but should be invisible once the turret is closed up.
I also got to work on the new tracks and ties. I painted the ties with Vallejo "Mahagony" along with a dark wash. There will probably be more of this in the ties' future. I painted the rains and the connector plates with primer flat black to start with.
All for now, more tomorrow.
Georg
