help with icicles
ambrose82
KitMaker: 249 posts
Posted: Tuesday, November 25, 2003 - 03:36 PM UTC
Anybody have a technique for making realistic icicles? I was planning on perhaps using clear modelling glue to afix a short length of clear fishing line to a test beam and then applying more clear modelling glue to the fishing line until it had enough build-up to no longer look like fishing line covered in modelling glue... However, I am open to what's worked for you...
Marty
KitMaker: 2,312 posts
Armorama: 1,054 posts
Posted: Tuesday, November 25, 2003 - 03:48 PM UTC
What might also work is stretched clear sprue. You could then texture it with some thick CA glue like Zap-A-Gap.
boosahmer
KitMaker: 651 posts
Posted: Tuesday, November 25, 2003 - 04:12 PM UTC
ambrose- here is a great link with info on making icicles. Also lots of other good info. Courtesy of our friend Roadkill
http://users.pandora.be/ronny.noben/website/index.htm
hope it works/helps!
Epi
KitMaker: 3,586 posts
Armorama: 2,556 posts
Posted: Tuesday, November 25, 2003 - 07:48 PM UTC
Ambrose82,
Two Part 5 Minute Epoxy works great too. I didnt use it for iceciles, but I did use it as "slobber" on the mouth of a "Taun Taun" figure. You put it in place and let gravity do its thing, then trim them, and if you want, spray dull coat to dull the shine or leave them bee for the shine.
Eagle
KitMaker: 4,082 posts
Armorama: 1,993 posts
Posted: Tuesday, November 25, 2003 - 09:35 PM UTC
Yep,
Boosahmer is right...that article that is hosted by Ronny "Roadkill" is cool and simple.
I can't see the article on his site, but that can because of my PC settings. when you can't see it either, just send him a PM.
Roadkill
KitMaker: 2,029 posts
Armorama: 822 posts
Posted: Tuesday, November 25, 2003 - 11:49 PM UTC
Hmmm I can see it, but here it is:
Eagle
Posted: Wednesday, November 26, 2003 - 12:03 AM UTC
Hmmmm....The only thing I see is a red X
Roadkill
Armorama: 822 posts
Posted: Wednesday, November 26, 2003 - 06:07 AM UTC
Grmbl, I forgot that darn providers has stoped remote linking
http://pnavy.com/roadkill/album08/icicles
Hope this helps
Hope this helps
Roadkill
Armorama: 822 posts
Posted: Wednesday, November 26, 2003 - 08:28 AM UTC
Hmmm, Eagle PM'ed me to tell me that he cant see the picture even if he is opening the link, can anybody else (besies me) open the link?
Matrix
KitMaker: 528 posts
Posted: Wednesday, November 26, 2003 - 08:49 AM UTC
I got it.
Eagle
Posted: Wednesday, November 26, 2003 - 08:55 AM UTC
Ronny,
I can see it now.... I had to disable my firewall to get to the page, but it's here now.
Thanks !
Thanks !
Sealhead
KitMaker: 427 posts
Armorama: 212 posts
Posted: Thursday, November 27, 2003 - 02:51 AM UTC
Here's something I found out when playing with different artist's gels, mediums and pastes. I put down a bead of gloss medium on a piece of Teflon I had. Then I took my hobby knife and made a number of scrapes, all in the same direction, perpendicular to the line of the bead. Then I let it dry and peeled it off the Teflon. Bingo, dripping water, or icicles for a roof line. This method gives you control over the length and irregularity of the drip or icicles.
For dripping water, leave it clear and shiny. For ice add white or white with a touch of blue. Or, for texture add microballoons, or white marble dust. Does this help?
Sealhead
(Kansas Sunflower)
Sealhead
parrot
KitMaker: 1,607 posts
Armorama: 1,581 posts
Posted: Thursday, November 27, 2003 - 08:29 AM UTC
try clear hot glue.not with a glue gun,but you can buy hot glue dishes from most craft stores that melt the glue sticks in a dish.use an old style toothpick,the ones with one side that's flat.apply and slowly pull down.apply some regular glue to the base of the icicles when they dry.when everything is solid add clear acrylis paint.
