Well, seems I need to do a couple of rounds of updates. Apologies for the image quality...these were all shot with my iPhone since I didn't really have time to set up the camera and tripod during the last few sessions.
After the modulation process shown in the last update, I went on to add paint to some specific areas such as the M240 travel ring, the ammo cans, smoke grenades and anything else that was a different color than the body. I also added some light chipping around the hatches.
At this point I also built the front CIP's which were made from thin card cut to match the size of the stickers that came with the kit. I painted them Sand, shot them with gloss and when that dried, I added the decals. I added a final coat of gloss to protect the decals and let everything dry again. Using a new x-acto blade and a straightedge, I lightly cut panel lines to simulate the beginning of delamination. Once these were done, I attached them to the front of the turret. I also added painted strips of paper around the turret to replicate the velcro tape.
Also attempted add the "51" to the battle board that hangs off the extended bustle rack but the decal provided was much too small compared to reference photos. The chevron decal was OK to use but I had to create a stencil for the numbers by photocopying the decal sheet at 150% and cutting them out. I then tacked it to the battle board and sprayed it black. This worked out well since I was able to place it slightly off-center as it is in the reference photo and it has a slightly imperfect appearance as you would expect from a field applied marking. Finally, I added two bolt heads that are shown in my reference photo. Most of the battle boards I've seen were apparently held on with zip ties but this was looks to have been bolted on.
Finally, it was time for the wash. After a couple of light coats of satin varnish over the whole model had been allowed to dry, I began applying the AK Interactive wash from the OIF kit. I applied it as a pinwash, around and into details rather than as an overall wash. To remove it I used Windsor & Newton Artists White Spirit. This process took much longer than expected and fortunately I had only applied the wash to the hull. I think I spent about 5 hours working it to get it to look just right. Another 4 hours went into working on the turret the following night.
I've begun adding the remaining decals starting with the iconic name of this beast.
The string of bones on the gun barrel broke off during the painting process but I'll add it back right at the end.
Once the decals are added to the skirts, I'll move on to painting and weathering the tracks and putting them on along with the wheels. Then it's stowage and crew. Still quite a bit to do...I'll just keep plugging along.
Thanks for looking.
