Did some work on my model. Applied a gloss coat of varnish, decals and did some basic pin washes (still have some cleaning to do). The 120mm shells are nearly done too.
À nos femmes, à nos chevaux et à ceux qui les montent !
GulfWarrior
Campaigns Administrator ARMORAMA
Texas, United States Joined: January 05, 2010
KitMaker: 1,051 posts
Armorama: 1,029 posts
Current campaigns:
I Like Big GUNS...And I Cannot Lie (2S1 Gvozdika)
Operation Snow White (Maultier w/ 37mm Flak Gun)
Stryker Campaign (AFV Club Stryker Dragoon)
1st Gulf War, 30th Anniversary (Dragon MLRS)
Removed by original poster on 09/12/19 - 12:11:17 (GMT).
Posted: Saturday, December 21, 2019 - 07:56 AM UTC
Hello ! My model is basically done ! I need to work on the figures and the diorama next. The ammo is done too. For APFSDS projectiles I used tips cut from needles, as I could have the correct dart length and was also more straight than resin. Since I had a problem with orange peel on my varnish (Didn't used the correct type of thinner) I've gone with a dusted and muddy tank, without going too crazy with it. Pigments were used as well as ak "dark mud" enamel product, mixed with plaster and modified with various pigments, on the tracks and wheels. Speaking of tracks, I managed to paint individually each rubber pads on each tracks 72 links. All to be covered up by mud It was a long a tedious task; some links managed to brake off during installation too. Bronco tracks are good, but the way the pads are glued makes too much room for the glue to move away by capilarity and glue the whole link. Any comments will be welcomed. Happy holidays to you !
The ammo is done :
Orange peel effect :
Finished model; in the end, making the model dirty and dusty was a fun thing to do and I like this look better than if it was too clean.
bison126
Correze, France Joined: June 10, 2004
KitMaker: 5,329 posts
Armorama: 5,204 posts
Thank you very much !! I’d like to ask you something if I may. On your « guide » about the tamiya Leclerc, you put a picture of a completed model on the first page. I’d like to know who makes the figures used in this diorama ? I made some research and thought they would be azimut or kmt but it seems they are not.
Thanks !
This is where I'm at right now with figure painting. They are all made by blast models. The level of detail is superb, especially on the helmets. I added some goggles and made the straps from masking tape. Next step is weathering/oil shading. Thanks for looking !
bison126
Sorry I missed your question. The figures are most likely from Blast Models. Blast released a number of sets when the kit was released. Unfortunately I don't have a reference number but from memory the standing crewmember is a separate reference while the gunner is part of a 3 figure set.
Olivier
Visit my site Click the banner
"La reine des batailles, j'ai nommé l'infanterie"
Napoléon
TopSmith
Washington, United States Joined: August 09, 2002
KitMaker: 1,742 posts
Armorama: 1,658 posts
Posted: Saturday, December 28, 2019 - 07:35 AM UTC
Roger that Olivier ! It looks like it’s not a figure that blast carries anymore..
Greg: the camo scheme was done using bluetac and masking tape. It’s the first time I have done a camo ! Much like everything else that was done during this project; it’s my first truly completed model. I only screwed up with the varnish but I’m satisfied with the weathering.
TopSmith
A very nice build - I will surely re-read it when I gonna start my kit in the stash. I do like it very much, it is very nice and inspiring me.
I have one minor comment for future builds: there are several "rules" when making bases for a model. One of them is to make the base as long as the tank is (as a minimum) including the gun, too. Otherwise the gun will be "off the base". I hope you see it.
This "rule" is similar to the typography in book making (or frame-sizing in photography) , a common "taste" to follow, however you are free not to. But most of the time these "rules" work very well and worth to consider during base (or diorama) design.
