Napoli, Italy
KitMaker: 880 posts
Armorama: 874 posts
Posted: Thursday, August 15, 2013 - 05:49 AM UTC
Hi all,can you please ID this device/antenna/support
.....and can you please suggest me links,photos,walkaround and so on about the thing.TIA
Ciro
Original photos from here:
http://spruebender.net/forum2/index.php?topic=838.0Bayern, Germany
KitMaker: 4,099 posts
Armorama: 4,067 posts
Posted: Thursday, August 15, 2013 - 06:42 AM UTC
Hi Ciro,
this is a Harris HF radio antenna. It was first seen on M1130
CV Stryker. The small box in front of it is the HF Coupler.
The mount before it is the third antenna mount installed on HMMWV`s. Usually, SINCGARS and FBCB2 equipped HMMWV`s have there antennas. Two whip antennas for SINCGARS and a smaller rod for EPLRS system.
HTH
Hans-Hermann
CAD Images mean nothing.
What does a rivet counter count on a cast or welded tank hull?
Napoli, Italy
KitMaker: 880 posts
Armorama: 874 posts
Posted: Thursday, August 15, 2013 - 07:06 AM UTC
Hi Hans-Hermann,thank you for the reply!
Do you know if the mount at the estreme right (2nd photo)has a name?!
Do you think that is it a field modification?!
Ciro
Rhone, France
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Thursday, August 15, 2013 - 08:27 AM UTC
Hi Ciro
Here's another view of the "Harris Corp RF-328A Fast Tune Automatic HF Antenna Coupler" :
A few more pics
here HTH
H.P.
#065
Missouri, United States
KitMaker: 2,605 posts
Armorama: 1,814 posts
Posted: Thursday, August 15, 2013 - 08:48 AM UTC
I looked at joining the Sprue Bender site but I don't want to jack with its unique password requirements. I would bet money that the vehicle is an M1165 and not an M1116 without a turret like the poster is stating. I would love to see the data plate.
:-X
IPMS # 41155
Current Campaigns:
Bayern, Germany
Posted: Thursday, August 15, 2013 - 09:07 AM UTC
Hi Ciro,
can`t tell what the name of the device is. I only know that it`s intended to install an antenna mount (SINCGARS or EPLARS)
through the extended roof.
Hans-Hermann
Louisiana, United States
KitMaker: 1,069 posts
Armorama: 1,062 posts
Posted: Thursday, August 15, 2013 - 01:26 PM UTC
Hi Ciro thanks for the info, I'll add it to my post on Sprue...
Building the impossible is my main goal. Build baby build never sleep!!
Napoli, Italy
KitMaker: 880 posts
Armorama: 874 posts
Posted: Thursday, August 15, 2013 - 05:27 PM UTC
Thank you fellows!
I've a couple of question.
Are you able to ID which type of mount is this?!I suppose it has also a dismounted harris HF coupler.
(Have you ever seen a so long cip !?)
TIA Ciro
#065
Posted: Thursday, August 15, 2013 - 05:50 PM UTC
The antennae mounts are certainly unique looking. The one on the right rear looks larger than the normal spring base mounts.
The CIP's are in the Department of Defense supply system in several different sizes and colors. You definitely don't see the longer, narrower rear panels too often.
The shorter,narrow panels on the each side at the rear of the vehicle were very common on HMMWV's when I was in Iraq in 2003 and 2004.
Good photo, thanks for sharing.
IPMS # 41155
Current Campaigns:
Napoli, Italy
KitMaker: 880 posts
Armorama: 874 posts
Posted: Thursday, August 15, 2013 - 06:26 PM UTC
Hi Brent,I bet that the support is a mix of supports,the square items after the antenna is part of harris hf antenna/coupler,you can spot it in the previous photos.
The base of the antenna looks like a normal support installed over an "extension" ?!can it be?!Who knows...
Cheers and thank you for the info about the cip!
Ciro
Rhone, France
Posted: Friday, August 16, 2013 - 06:14 AM UTC
Here's a Marine Corps Humvee aboard a LCAC that's fitted with a similar setup :
H.P.
Napoli, Italy
KitMaker: 880 posts
Armorama: 874 posts
Posted: Friday, August 16, 2013 - 06:43 AM UTC
I love you Frenchy !
Thank you!
Napoli, Italy
KitMaker: 880 posts
Armorama: 874 posts
Posted: Friday, August 16, 2013 - 08:06 AM UTC
Frenchy,do you have other pics of m1165?!Besides the ones that we can see trought the sites dedicated to the Humvee....cheers
Ciro
Rhone, France
Posted: Friday, August 16, 2013 - 09:10 AM UTC
You're welcome Ciro
I'll see if I can find other M1165 pics but I'm no Humvee expert so I may have to double check them to be sure
At least I can send you a hi-res version of the picture in my last post if need be...
H.P.
Napoli, Italy
KitMaker: 880 posts
Armorama: 874 posts
Posted: Friday, August 16, 2013 - 05:00 PM UTC
Hi Frenchy,well if you have a hi-res of the last one it will be great!
You can post it here,if you want.
And if you've other photos of M1165 I'll be glad to see them.
Ciro
Rhone, France
Posted: Friday, August 16, 2013 - 05:57 PM UTC
Watch your mailbox
H.P.
