The last week or so has seen some significant progress being made, firstly on the turret:
Its had a lick of paint which went on nicely and the ECM box has been finally attached. This did require the attachment of another ribbed pip which can be seen here behind the commander's hatch
The paint still needs work done with washes etc and various details picked out but that will happen soon enough
So next job was to make a start finally on the bar armour. To do this I printed out my plan, gave it several coats of pray varnish to protect it, then a quick blast of spray mount which makes the surface sticky to hold the thin strips of plastic in place when I am building the frames like this:
I also built a job to be able to drill the holes properly aligned
This is just two square section rods glued together with a 0.6mm hole drilled through it and slots cut at the right locations to accept the bar armour slats and hold them firmly in place. There are still some misalignments - especially if I get the initial alignment wrong, but its vastly quicker and more accurate than my previous jigs from 2 years ago!
Here is the first set of bar armour panels for the turret:
As you can see there are some irregularities so I'm thinking about trying the larger panels again. You can see from the centre one that one of the main problems is keeping things straight - the middle section of that panel is narrower that the ends. The left and right panels also show other misalignments, some of which I may live with as this stuff gets knocked about a bit in real life anyway. Some of it is just to bad and will have to be replaced however.
That said, I'm not that unhappy with the first attempts. I've just ordered another 10 packs of #103 Evergreen strip (0.25 x 1.5mm) which should keep me in enough plastic for a while
