Well, it's been a while since I added to this Blog but suffice to say that I have progressed when I had time between other projects.
@retiredyank - Matt,
If you had a couple of bottles on rum, something tells me that you'd probably just glue the wheels to the missile tube. :-) Something like the fastest 14 wheeled dragster on the planet!
888888888888888888888888888888888888888888888888888
The painting issue is still plaguing me and I've wasted a lot of time on it. to date I've used an entire jar of Tamiya XF-65 Field Grey on the parts that show paint and there's still a ways to go. The whole issue is to get paint down into areas that won't be easily accessible as construction advances. One other point to keep in mind is that as the build continues, certain areas are getting congested and parts placement becomes an issue.
Rather than give a belaboured explanation of each step (that most don't read anyway) I'll let the pictures speak for themselves for the most part. :-)
The first six images show the construction of the rear Jacking/levelling mechanism. A fair number of parts, mostly good fit and a few more delicate parts left off for later.
Putting on the ladders. This is the rear most section of three separate sections that make up the mechanism.
The inner most section.
Rear and Inner joined.
All three sections in position.
Next is attaching the fenders and starting on the storage/equiment boxes. The main fender section is one single piece that covers both sides. The fit is not bad but a little tricky in areas. The boxes, almost perfect fit of the parts.
So far the instructions have been near perfect, compared to some manufacturers. BIG thing to remember is to take your time!
Jan
