First of all some words on the previous pictures.
Idler wheel: inside the box you will find both drive and idler wheel. As drive wheel I will use the metal one but on the front I will put the plastic one. To adapt it enlarge the hole from 3 mm to 4 mm then the metal adapter will work fine.
The upper inside part of rear horn laks of any datails so I rebuilt rivets and mudscraper.
I rebuilt some parts in the rear due the heavy thickness of Tamiya parts.
Some parts are pure invention as side support on gas tank.
Sponson are really well moulded but they lack of any detail on the inside area near the gun. Looking at sponson picture it seems armour makes a small lips so I glued a 0.5x0.5 plastic strip to riproduce it.
The Bovington MkIV has the hatches on the upper hull but no WWI tank have them. Nobody know when and why Bovington tank had them.
Tamiya model has three Lewis guns but I will chenge them with some others from Takom model I think they are better done.
Tamiya has another problem: guns and their ball mount are moulded togheter so the ball lacks of the two small holes on the upper and bottom area. Now I am casting a resin copy ot these parts again from Takom model.
In my opinion one of the worst part in this model is the unditching rail. Really toooooo thick.
It's very hard to rebuilt them due their shape but al least I wuold modify the horizontal strip which is the most seen part.
So I cut the original one and changed with 2 mm styrene strip.
I will join all parts only when the horn will be complete. It will not be an easy task!
I rebuilt also the roof side support
And supports on upper rear horn with some scrapped PE parts.
Drive wheel with its final drive gear. I pain the interior areas with Vallejo Cavalry Brown which I belive it's a good match for the old red primer.
The cab needs some filling on the rear. Erase rails support (they will be redone) and fill holes.
My Landship will have a crew in the drive cab and - may be - in the rear upper port.
On the front there will be two figures rappresenting Tank Commander (2/Lt J.O. Evans, KIA in Fontaine Notre Dame, 11/23/1917) and Driver (Pte A. Bates, KIA in Fontaine Notre Dame, 11/23/1917) so I redo the internal cab frame (not so sure it is correct but I think it works). The rear plastic sheet will be painted black to hide the empty hull.
I casted in resin side vison block and now, after some cleanig, they are ready to be glued inside the cab
New Lewis ball mount from Takom kit
and pistol port for my next project: converting a Takom Male landship to a Supply Tank with the top towing arrangment and - I hope - her supply sledge.
More to come...
Pierantonio
