ATF Dingo 2
zorrolobo
KitMaker: 1,457 posts
Armorama: 1,440 posts
Posted: Monday, December 08, 2014 - 10:18 PM UTC
You didn't mess up. You followed Revell's instructions. Revell messed up. But I guess you are right, there are so many variations that "anything goes". As for my model. I will follow the pictures and not the instructions.
zorrolobo
Posted: Wednesday, December 10, 2014 - 09:00 PM UTC
Base color ready. Working on masking:
Lighting was very bad giving it a grayish tone. But I used the Vallejo ISAF color set.
zorrolobo
Posted: Sunday, December 14, 2014 - 10:23 AM UTC
Beige and brown ready. going for green:
zorrolobo
Posted: Monday, December 15, 2014 - 12:10 AM UTC
Done with the green:
Although I used the Vallejo ISAF colors I feel the green a bit dark when compared to actual photos. I will use a couple of filters and maybe a little old fashioned dry brushing.
bat-213
KitMaker: 902 posts
Armorama: 788 posts
Posted: Monday, December 15, 2014 - 05:45 AM UTC
zorrolobo
Posted: Monday, December 15, 2014 - 11:27 PM UTC
Thanks Roy.
mvaiano
KitMaker: 1,054 posts
Armorama: 1,050 posts
Posted: Tuesday, December 16, 2014 - 12:15 AM UTC
Hi Marcos!
Lovely Dingo. I can't wait to see it finnished.
BTW, what do you think about build it w/o any AM?
Cheers!
Marco
Cheers!
Marco
zorrolobo
Posted: Tuesday, December 16, 2014 - 01:22 AM UTC
Thanks Marco.. About building it w/o AM the kit is ok. The PE for the interior cannot be fully appreciated. I thought about building it with the removable top, but the lousy fit would just not allow it. Check out Olivier's build, he did it without AM and looks great. Just be very careful with the painting instructions, which are wrong. Check photo sources on internet to be sure. The exterior AM PE does add to the vehicle. Cheers!
zorrolobo
Posted: Tuesday, December 16, 2014 - 01:25 AM UTC
I have added a couple of very light filters.
mvaiano
Posted: Tuesday, December 16, 2014 - 03:19 PM UTC
Thank you Marcos!
I saw Olivier's Dingo and you're right. He did a great job w/o any AM parts.
Cheers!
Marco
Cheers!
Marco
terminators
KitMaker: 1,932 posts
Armorama: 1,907 posts
Posted: Tuesday, December 16, 2014 - 11:20 PM UTC
nice colors .
zorrolobo
Posted: Saturday, December 20, 2014 - 12:10 PM UTC
working underneath with pigments and enamels:
zorrolobo
Posted: Sunday, December 21, 2014 - 08:18 AM UTC
zorrolobo
Posted: Sunday, December 21, 2014 - 10:37 PM UTC
Almost done!
zorrolobo
Posted: Tuesday, December 23, 2014 - 01:21 AM UTC
zorrolobo
Posted: Tuesday, December 23, 2014 - 12:54 PM UTC
almost.
zorrolobo
Posted: Thursday, December 25, 2014 - 11:59 AM UTC
zorrolobo
Posted: Saturday, January 03, 2015 - 12:14 AM UTC
Working on the crew:
chnoone
KitMaker: 1,036 posts
Armorama: 1,033 posts
Posted: Saturday, January 03, 2015 - 05:36 AM UTC
I just realized that the colors in the instructions are reversed!
Olivier followed the instructions to the T and ended up like this:
But the real vehicle should look like this:
The olive is switched with the brown!
Another BooBoo for Revell
Taking a quick look through the pics on the net and a saw quite a few Dingos with the brown instead of the green dominating camo pattern.
To me it looks like the guys in the field had a better understanding of which colors make more sense in such an environment then the desks warriors at the "Erprobungsstelle".
This one looks a lot more like Olivier's:
https://www.flickr.com/photos/augustinfotos/5028754217/
Nice builds never the less ... both of them
Christopher
zorrolobo
Posted: Saturday, January 03, 2015 - 07:30 AM UTC
Good find. Now it is truer than ever: with the Dingo any which way is fine! Thank you
zorrolobo
Posted: Saturday, January 03, 2015 - 07:51 AM UTC
Christopher, did you find any other pictures with that same pattern. Because I have been searching and I have found many with the reversed pattern,the sand and brown pattern, but none like the one you found which is exactly the pattern Revell suggests.
zorrolobo
Posted: Saturday, January 03, 2015 - 07:56 AM UTC
From what I have seen on the web it looks like the sand and brown pattern was an earlier pattern, and at some point it was switched to the three color pattern with several variations in between. But maybe one of our German friends can share some light on the subject.
zorrolobo
Posted: Saturday, January 03, 2015 - 08:21 AM UTC
In the Flickr file in your link I found two more photos of that pattern, here is one:
And reversed:
and to make it more interesting, two more variants:
And reversed:
zorrolobo
Posted: Saturday, January 03, 2015 - 08:25 AM UTC
Although I had already posted them, but so that you can see them all together, two more variations:
zorrolobo
Posted: Saturday, January 03, 2015 - 08:31 AM UTC
So as a conclusion, I quote Olivier: "painting a Dingo in Desert camouflage is really up to you". So there!
