Hi, guys!
Figure update:
I carried on a little work on the figures. I found a couple of suitable ones in a Tamiya kit. They still needed some minor work in order to improve the stance in relation with the scene.
First, the schutze / radio operator:
Is made from a single styrene character, but i needed to twist the angle between the upper and lower body as much as possible, given the cramped position and the center of the scene:
The arms position have to be a little adjusted. Here temporarily held in place by blue-tac:
Finally, the position of the right hand was adjusted by rapport to forearm, to achieve a more natural fit with the carbine. The picture shows the issue, not the solution. Meanwhile, the problem was solved. Unfortunately, I took no photo and now the figures are in painting stage:
The vehicle commander is bashed from two characters, both Tamiya. In fact, only the head is changed (the original is wearing a helmet):
Two issues I addressed here: I gave a little tilt to the head (almost imperceptible, but changes significantly the stoned Tamiya stance) and the position of the right hand, which I had to cut it and twist it from vertical to horizontal, according to my needs:
Thank you for following, commenting and constructive criticism.
Gabriel
