Hosted by Jacques Duquette
T-28E gun type
jwest21
KitMaker: 3,374 posts
Armorama: 3,126 posts
Posted: Monday, August 17, 2015 - 05:00 AM UTC
What kind of gun does the T-28E have? I am looking for a metal barrel for the Hobbyboss kit, but am striking out. Looks longer than the KT-28 gun but doesn't look long enough to be an L-10. Thanks
KurtLaughlin
KitMaker: 2,402 posts
Armorama: 2,377 posts
Posted: Monday, August 17, 2015 - 05:13 AM UTC
I think it was whatever the base tank had mounted, the KT-28 or the L-10. I'm pretty sure there wasn't a gun made specifically for the uparmored vehicles.
KL
KL
jwest21
Posted: Monday, August 17, 2015 - 05:23 AM UTC
Were those the only two options? If so, I think this is boxing is the L-10. Do you know if the L-10 barrel from the KV-1 series would be the same? I see a few AM barrels for that...just not sure the collar around the barrel end is the same
Dodger013
KitMaker: 410 posts
Armorama: 83 posts
Posted: Monday, August 17, 2015 - 05:29 AM UTC
It is an L-10 gun, slightly larger than the KT-28. The one on the early KV-1 and T-34 was the L-11.
jwest21
Posted: Monday, August 17, 2015 - 05:54 AM UTC
Ah, OK. I thought some KV-1s had the L-10- Lion Roar sells an L-10 barrel for the KV-1. I assume that's a misprint and should be an L-11?
http://www.ebay.com/itm/PE-Photo-Etched-1-35-L-10-76-2mm-L23-7-For-KV-1-Metal-Barrel-1pcs-LB3508-/371057050454?hash=item5664b94356
KurtLaughlin
Posted: Monday, August 17, 2015 - 05:56 AM UTC
Armo makes both KT-28 and L-10 barrels in 1/35.
KL
KL
jwest21
Posted: Monday, August 17, 2015 - 06:00 AM UTC
KL
Oh cool...perfect! Do you have a recommended supplier? I can look online if you don't
KurtLaughlin
Posted: Monday, August 17, 2015 - 06:06 AM UTC
Quoted TextArmo makes both KT-28 and L-10 barrels in 1/35.
KL
Jadar Hobby in Poland. Sprue Brothers, M&Models in Chicago, or CRM in St Louis might carry them.
KL
jwest21
Posted: Monday, August 17, 2015 - 06:31 AM UTC
thanks!!!!
Dodger013
KitMaker: 410 posts
Armorama: 83 posts
Posted: Monday, August 17, 2015 - 07:10 AM UTC
Looks way too long for an L-10 so I would figure a typo.
