How to make realistic Ice
#130
Noord-Holland, Netherlands
KitMaker: 8,797 posts
Armorama: 4,190 posts
Posted: Wednesday, June 19, 2002 - 06:49 AM UTC
I`m want to make a diorama which shows a tank that is stuck in the mud and is waiting to get towed away next to the road is some frozen water (lake) because my diorama is situated in russia ww2 at the beginning of the winter.
the problem now is: A lot of things I have sorted out already but I don`t know how to make realistic ice. In Holland when you look at the ice you can see through it and under the ice it`s dark grey to nearly black with white spots (captured air) and big cracks
I tried with plexiglass but I wasn`t satisfied while it lacked realism
Could someone help me out with this problem
Greetz Robert "FAUST" Blokker
"Wees niet onverstandig, haastig of voortvarend; alles sal regkom, as ons almal ons plig doen".
FUTBOL KAVGADIR!!!!!!!
European Union
KitMaker: 2,289 posts
Armorama: 1,231 posts
Posted: Wednesday, June 19, 2002 - 06:59 AM UTC
Now here's a challenge !
I never tried it, but I would attempt the following :
Start with a dark brown river bed / pool bottom
1) make clear resin water
2) paint white "air bubbles" on the surface with semitransparant paint mixture
3) add an overall gloss finish, so there's clearly a layer of ice OVER the air bubbles
4) add snowdust on certain areas, blown together by wind like in real life.
I'd make sure there's some dead reed growing through the surface, that adds to the wintery feeling.
Just a thought...
Jan
Who the hell is General Failure, and why was he reading my hard disk ?
Where's my funky Iraqi general rank that was here on my profile a few years ago? Did they strip my rank, after all I've done for this forum ? Robbery!!
Uusimaa, Finland
KitMaker: 1,088 posts
Posted: Wednesday, June 19, 2002 - 07:01 AM UTC
This is just a wild guess but how about clear resin, maybe 2-3 layers? You could start with dark coloured layer and the surface could be almost clear...some snow (baking soda) on surface, maybe some "wet spots" where the snow has melted and the depth would be visible...
There are so many kinds of ice and only some of them are clear transparent..
I would also go for some vegetation sticking up from water near dry land.
Sounds very interesting BTW! I was playing with an idea myself where a tank would be crashed through ice, stuck...
Toni
Pig # 60
O-Ren Ishii: You didn't think it was gonna be that easy, did you?
The Bride: You know, for a second there, yeah, I kinda did.
Uusimaa, Finland
Posted: Wednesday, June 19, 2002 - 07:03 AM UTC
Heh...This is always hilarious when same kind of tips are delivered simultaneously!
Toni
Pig # 60
#130
Posted: Wednesday, June 19, 2002 - 07:13 AM UTC
well thanks for the tips guys
I hope it will work out good
Hey and that clear resin thingy you just called is that what they sell in the modelstores as instant water ??
#130
Posted: Wednesday, June 19, 2002 - 07:14 AM UTC
Oh before I forget to ask this ...
What will be the best way to simulate cracks
Greetz Robert "FAUST" Blokker :-) :-)
European Union
Posted: Wednesday, June 19, 2002 - 07:24 AM UTC
The most convincig way to make cracked ice would be to make pieces of ice that are moved over / under other pieces, maybe a few panes of ice that are not perfecly horizontal but stick out just the tiniest bit out of the water, maybe a few smaller pieces of broken ice panes that lie around on other tops. Don't forget a few ducks paddling around in the open piece of water in the middle.
Just a thought. To make a horrid little diorama you could shove a drowned victim floating UNDER the ice surface.... his pale face against the surface... no, that's sick. Guess it's bedtime after all.
staff_Jim
PublisherNew Hampshire, United States
KitMaker: 12,571 posts
Armorama: 6,599 posts
Posted: Wednesday, June 19, 2002 - 07:31 AM UTC
Jan,
Don't ducks fly south in Russia?
Jim
#130
Posted: Wednesday, June 19, 2002 - 07:32 AM UTC
thanks for the tip and the well let`s say a bit macabre dio idea maybe I use it
no i`m not going to use that...... Joke :-) :-) :-)
but anyway my ideas for the dio I`m planning is getting better and better with every post I make here and I will make an article of the whole process
so I`m thinking of a credit list to thank all that helped me further.
South Australia, Australia
KitMaker: 1,958 posts
Armorama: 1,003 posts
Posted: Wednesday, June 19, 2002 - 08:22 AM UTC
Hi!
i read an article of MIG=Miguel Jimenez, where he made a Tiger I stuck in the ice of a lake, he used wax from candles, just make a box, melt the candle wax on it, let it dry and voilà, it´s done. And you can easily crack it in parts, if you like...
HTH
Paulo R Castro
Whatever happens keep modelling!
KitMaker: 1,586 posts
Armorama: 1,225 posts
Posted: Wednesday, June 19, 2002 - 01:49 PM UTC
Depends too on the depth of the ice. A shallow pool might totally freeze through... in which case "solid" color would be more likely. Try using clear resin (EZ Water) or multiple coats of acryllic floor way, and add in a middle coat of whiteacryllic to the liquid, so you get a milky haze. Then add a few more layers of clear, add microballoons for snow accumulation, and there ya go. For "cracked sheets of ice", try painting the thin microscope slide glass white, then break a few and insert into the wet resin or acryllic floor polish. Looks pretty darn good!
Keith
#034
Setubal, Portugal
KitMaker: 1,718 posts
Armorama: 1,130 posts
Posted: Wednesday, June 19, 2002 - 03:24 PM UTC
Hi,
Here
Tiger I Ausf E Early Version you can see the results of the technique refered by Paulo (ArmouredSprue).
At ML forums there are a thread where MIG explains how he did that.
Hauts-de-Seine, France
KitMaker: 1,757 posts
Armorama: 929 posts
Posted: Wednesday, June 19, 2002 - 07:16 PM UTC
Instead of using candle wax, you can use parafin.
I got some at my local supermarket. It's the kind used to seal home made jam.
It's just so cheap...
penpen
Big Bad Wolf N° 3, huffing and puffing...
life is but a dream...
from Paris, France, Europe
#034
Setubal, Portugal
Posted: Wednesday, June 19, 2002 - 07:52 PM UTC
Hi,
Here
ML Forum is the post where MIG explains how he did the ice on his Tiger dio.
Oklahoma, United States
KitMaker: 6,043 posts
Armorama: 4,347 posts
Posted: Wednesday, June 19, 2002 - 08:29 PM UTC
In case you want to see pics of this Dio
http://www.missing-lynx.com/gallery/german/migtiger.htmenjoy
Well beat me too it quick one.
#130
Posted: Thursday, June 20, 2002 - 01:19 AM UTC
well and again thank you all
every time I look I can choose out more and more ways to make ice
now I can experiment what the best way for me is
#130
Posted: Thursday, June 20, 2002 - 01:27 AM UTC
I`ll tell you all which technique or combination I used
Antwerpen, Belgium
KitMaker: 2,029 posts
Armorama: 822 posts
Posted: Thursday, June 20, 2002 - 03:15 AM UTC
Hello,
A while ago I have found a nice litle article from Charles Reading "Creating Simple yet Effective Ice"
I have put it on my site (under tips) and you can find it here, hope it wil help.
http://users.pandora.be/ronny.noben/website/Start.htm Ronny
"At my Signal .......................... Unleash Hell!"
"What we do in Life ................ Echoes in Eternity"
#130
Posted: Thursday, June 20, 2002 - 06:12 AM UTC
Antwerpen, Belgium
Armorama: 822 posts
Posted: Thursday, June 20, 2002 - 06:47 AM UTC
Faust,
I just looked over it, and it seems to work, but here it is again
http://users.pandora.be/ronny.noben/website/index.htm or
http://users.pandora.be/ronny.noben/website/start.htm You wil be send to the main page and from there you klick on the TIPS button (shermans on the left), if the URL does not work, try the link under my name - Roadkill's
Modeling Corner
Ronny
Armorama: 929 posts
Posted: Thursday, June 20, 2002 - 07:37 AM UTC
No luck with your links either...
penpen
#130
Posted: Thursday, June 20, 2002 - 07:39 AM UTC
Antwerpen, Belgium
Armorama: 822 posts
Posted: Thursday, June 20, 2002 - 02:42 PM UTC
Ronny
#130
Posted: Thursday, June 20, 2002 - 04:10 PM UTC
Nope still no succes
KitMaker: 4,287 posts
Armorama: 1,867 posts
Posted: Thursday, June 20, 2002 - 11:31 PM UTC
Another method for making some smaller patches of ice, like thos along the shore of a lake or stream is to use super glue. Lay down a sheet of plastic wrap (Saran Wrap here in the States) and then apply a puddle of super glue. move it around with a wooded toothpick or something and then hit it with excellerator. When it is dry is resembles jagged ice very well and it doesn't stick to the plastic wrap.
"Q"
"Don't fear the night, fear what hunts at night"
