I finished installing the remainder of the PE parts.
Rear Step Ladder:
Tow Cable Stowage Brackets:
BTW: NO tow cable supplied within the kit.
Filler Plates on the Right Front Corner of the Fighting Compartment:
While the Gator Grip Glue dried I went ahead and started on a job that might turn people away from buying this kit.
The Tracks:
The links are very small but if you're able to snip the injection gates off real close sanding the nibs is very easy and goes quickly.
10 of 107 links per side (as per the instructions)
After taking the above photo I put together both road wheel bottom runs in about two hours. That's removing the links from the sprues,cleaning up and gluing the links together.
I'll have to start some painting before continuing.
I take the weekends off so i'll see you Monday
Tony lee
