This is my build of the SDV Models T-34/85 vz. 1944.
This 1/87 (HO in model railroad scales) is a new injection molded kit with a small photo-etched fret.
It requires some clean up after cutting the parts from the thick sprues, and the carving of some excess plastic from some notches to allow the upper hull to fit over the rear fenders. Otherwise fit is good. There is some flash to remove, too, although it is thin enough to brush off with my fingers.
[i,g]http://armorama.kitmaker.net/photos/feature/5553/sdv_t34_build24__404x602_.jpg[/img]
Liquid glue filled in the slight gaps well. But that made glue-squishies that needed to be shaved off the turret. That removed some of the foundry casting roughness from the turret. I used liquid glue and a stiff brush to make it rough again.
