A slight upgrade to the Taska Jumbo
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Monday, September 26, 2016 - 11:12 PM UTC
I have it painted in the base coat.
Just some more trim painting to go then it's on to the track.
Donald
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Monday, September 26, 2016 - 11:52 PM UTC
I always enjoy your SBS builds. Your comments and observations are insightful and are very helpful and useful. I also appreciate your rather matter of fact approach in discussing the positive and negative aspects of the build. No drama just the facts.
"No plan survives contact with the enemy." Helmuth von Moltke the Elder
Posted: Tuesday, September 27, 2016 - 06:46 PM UTC
I'm glad that you like it, to many just post the finished model without any info as to how they gat there.
Donald
Posted: Tuesday, September 27, 2016 - 06:49 PM UTC
Now to continue, I have installed the Bogie Trucks, the front is slightly lower because of the extra weight of the additional armor and the front concrete.
I'm not quite sure how accurate this is, but I think it looks about right.
Donald
KitMaker: 2,275 posts
Armorama: 2,233 posts
Posted: Tuesday, September 27, 2016 - 07:46 PM UTC
Let me help Donald,
Here is a more direct link to the website you provided , for the Sherman pix.
http://www.worldwarphotos.info/gallery/usa/tanks/
Posted: Saturday, October 01, 2016 - 06:29 PM UTC
I finally have the Duck Bill extenders for the track finished, except for the painting.
Here is how I did it .
There are tiny nuts to be installed on the end connectors.
After the glue sets trim off the tabs.
Next you will have to drill out the center hole only in the end connector, it is too small for the center pin on the duck bill.
Posted: Saturday, October 01, 2016 - 06:36 PM UTC
Here's what the pins look like.
I installed the duck bills onto the end connectors but left them on the sprue for painting.
Next I'll be working on the rest of the track.
Donald
Michigan, United States
KitMaker: 4,021 posts
Armorama: 3,947 posts
Posted: Saturday, October 01, 2016 - 07:10 PM UTC
Why do you need to drill that center hole at all? I'd simply cut off that middle nub and glue the EEC onto the end connector since you already have two other locating pins.
Just a thought.
Roy Chow
Join AMPS!
www.amps-armor.org
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Saturday, October 01, 2016 - 07:20 PM UTC
Just a thought.
Hi, Roy!
Extra strength, maybe? I'd trim the center pin off, myself. Once I complete a model, I very rarely handle it once it's placed in one of my display cabinets...
Posted: Saturday, October 01, 2016 - 07:52 PM UTC
Just a thought.
That would work too I guess, it's just the pins aren't in a straight line and you gould get the extenders on upside down if not careful .
Donald
KitMaker: 105 posts
Armorama: 85 posts
Posted: Saturday, October 01, 2016 - 09:38 PM UTC
Love the Kaizen tracks. I just built the T54E1 and extended end connectors. Excellent tracks.
But mine assemble differently. On the ones I built, the duckbill had an end connector molded on, so it just replaces the end connector from the track kit.
Either way, the Kaizen tracks are going to be my go-to tracks for indy link needs.
Posted: Wednesday, October 05, 2016 - 06:04 PM UTC
I have been working on the rest of the end connectors without the duckbills. I have found an easier and neater way.
First apply a little liquid glue to the small hole in the back of the connector.
You should get a small bead showing through the hole.
Quickly place the nut with its sprue carrier in the hole.
Trim off the sprue carries after glue sets up.
Posted: Wednesday, October 05, 2016 - 06:10 PM UTC
Since I'm using the Duckbill end connectors I only finished half of the regular ones.
Here are the pins, each cut to 12mm long with the ends filed to remove any burrs .
Posted: Wednesday, October 05, 2016 - 06:16 PM UTC
I super glued the pins into the Duckbills.
All ready for final assembly.
I'll be assembling the track next, man I hope this works.
Donald
#023
Zurich, Switzerland
KitMaker: 2,058 posts
Armorama: 1,656 posts
Posted: Thursday, October 06, 2016 - 03:22 PM UTC
Hi Donald
Great work so far and thanks for documenting it. The work on those tracks looks daunting, you're a braver man than I am.
Cheers!
Stefan
Too many models - too little time...
Posted: Sunday, October 09, 2016 - 12:49 AM UTC
Well I finally have them assembled and installed, here is how I did it.
I found that I got a little too much super glue on the pins, and instead of scraping the pins down I counter bored the holes in the track blocks about 1mm deep to clear the glue.
Posted: Sunday, October 09, 2016 - 12:52 AM UTC
Posted: Sunday, October 09, 2016 - 12:59 AM UTC
I made eight sets of ten for each side, it turns out this is a little too long for the Taska kit.
I had to shorten the track runs from 80 down to 79 shoes.
They are very flexable.
You will have to add a little thin super glue to the outside of the inner end connectors to make sure they stay together.
Posted: Sunday, October 09, 2016 - 01:05 AM UTC
Here's how they look on the kit.
This is an example of why I like to have the sponsons open, it makes the track install so much easier.
As for these tracks, I'm glad that I only bought one set, the Bronco tracks are a lot easier. I have their panzer IV track set that looks a lot easier. For the sherman (NEVER AGAIN)
Donald
Antwerpen, Belgium
KitMaker: 191 posts
Armorama: 120 posts
Posted: Sunday, October 09, 2016 - 04:29 AM UTC
Looks like a hell of a job but it sure was worth it; looking great!
Kind regards
Steven
Posted: Monday, October 10, 2016 - 12:59 AM UTC
Kind regards
Steven
Thanks , I'm glad you like it.
Donald
Posted: Monday, October 10, 2016 - 01:01 AM UTC
Posted: Monday, October 10, 2016 - 01:06 AM UTC
Now to paint and install them.
Donald
Posted: Tuesday, October 11, 2016 - 06:05 PM UTC
Painted and installed.
Just a small post today, the next will be when I have it all finished and weathered.
Donald
Posted: Tuesday, October 11, 2016 - 06:27 PM UTC
Coming along nicely. Those tracks were a bear by the looks of it. Lots of work but worth the effort as they look good on the tank.
