Your model needs to be in an art gallery.
Simply said: Breath-taking build.
If I were Miniart I'd buy your photos to use them as reference and marketing material... Stunning. Congratulations!
cheers,
Zsolt
(btw somebody mentioned earlier that your build inspires and wakes up an instinct to buy this kit as soon as possibleanother good point to contact Miniart's marketing department
I was going to buy this kit,but after looking at yours there is no way on earth I could do it justice
Looks fabulous to far. The figure too. Stalingrad I believe?
Beautiful work Dmitrii! I'm working on the old dragon su-85M and after seeing your amazing work here I'm ready to buy this kit!!
Look forward to seeing how you finish this one. Seems like you have a diorama or vignette plan for this, no?
Your weathering looks great so far. Do you like those new oil brushes?
Simply beautiful Dmitrii,
I think this is the nearest I’ve seen to a perfect build, so many little details look exactly right. I like everything – just to take one example of many, your painting of the interior walls is just exquisite. A great pity you sealed it up though – I recently completed MiniArt’s SU122 and found that by carefully cutting through the rear deck/panels (keeping the mudguards attached) I could slide it on and off to reveal the interior.
Looking forward to seeing the diorama – your excellent photography is also hi-res perfect too, although is the colour-balance too intense? The green looks very bright, maybe you will fade it when you do the weathering...?
I agree with what someone else has said, MiniArt should be employing you!
Cheers, Tim
Meant to ask earlier in the blog, which turned barrel did you use.
The blue crate on the back deck looks great. I also like the Russian back pack on the right side of the hull.
