Just though I'd post a few pictures of my 1/16 M26 Pershing build.
I hope you like'um, there will be more shots added next week as the build progresses.
Let the fun begin....
p.s If you don't see any pictures at the links, come back at a latter time, there might be bandwidth problems with the photo server.
One of the first steps in the build of the M26
Here's another shot of the road wheels.
And another.......
Here's a shot of the first six wheels attached to the hull.
You must remember that each side has it's correct wheel labeled on the inside of the suspension mount as well as the suspension crank arms for each wheel.
And here's another.....
The instructions say to put on the back six wheels first, starting on the right side.
A shot of how the crank arms mate with the suspension tension rails on the inside of the hull.
Check to make sure all wheels sit at the same level once the springs are loaded, if not, you may to need to adjust the crank arm slot, BE VERY CAREFUL in doing so.
The next step, the upper road wheels, straight forward construction, nothing to really watch out for here
T-Link
