Of interest is the old box has made in Japan on it, while another kit I got a few months ago has made in the Philippines. However, the upper hull is badly warped, not sure when that happened, but it is too badly mangled to salvage.
At the time the Tamiya kit came out I had been working on some bits and pieces to make it easier for me to strip it down, and perhaps make a T-54.
To add thickness to the turret sight and mg openings I made some oval inserts out of plastic that were then sanded down to fit the Tamiya turret front. Next up I made a "bare" fuel can holder. I made a turret fan cover, but I think the Takom T-54 is good enough.
Going through the forum I learned about the ridges on the wheels, so I added them using stretched sprue. I plan on using the best 2 wheels as masters and cast my own wheels.
For me some pieces are better in resin than photo-etch, and I have been able to find most of what I wanted from Legends and DEF. I am still looking for a DEF IDF T-54 conversion set. I want to get that rear hull stowage bin piece, or at least measurements so I can make my own.
I intend to make a fuel tank line connection fitting, and replacement tow hooks. Are there any suggestions for some simple bits and pieces you think we can use?
