Merkava IV Detail Questions
cabasner
Nevada, United States
KitMaker: 1,083 posts
Armorama: 1,014 posts
Posted: Sunday, November 12, 2017 - 05:23 PM UTC
Excellent work Curt, I can almost smell the dust! What color did you use?
Thank you, Israel, coming from you that’s quite a compliment!
The paint is one of the common Tamiya mixes discussed often for IDF colors. If I recall correctly, it’s 2:1 Medium Gray to Khaki, but I’ll verify that tonight, as well as the paint numbers.
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 921 posts
Armorama: 919 posts
Posted: Sunday, November 12, 2017 - 08:26 PM UTC
Another inspiring model for the IDF fans!!! Well done Curt.
Israel thanks for the clarification on the system terminology.
cabasner
Posted: Sunday, November 12, 2017 - 09:51 PM UTC
Nikos, very kind of you...many thanks!!
Armorsmith
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Sunday, November 12, 2017 - 11:05 PM UTC
Very nicely done. Great paint and weathering and kudos on the ball and chain armor.
DonnyT
Singapore / 新加坡
KitMaker: 74 posts
Armorama: 67 posts
Posted: Monday, November 13, 2017 - 08:11 AM UTC
Curt, very good job on your MK 4 LIC.
The cable guide for the 50 Cal looks good too, what you use to replicate it?
Thanks, Donny. Actually, the cable conduit was a little more involved than it needed to be. I started with a 0.75mm plastic rod, cut to length. Then, I cut a few pieces of scrap photo etch brass, and bent the pieces about 20 degrees. These pieces I glued to the bottom of the plastic rod, to replicate the 'feet' that you see toward the front of the cable conduit. Then, because the 'back' side of the conduit in smooth (i.e. doesn't have those 'feet'), I filled in the back from the top of the plastic rod with thinly rolled epoxy, then used super glue to make the back side (relatively) smooth. Then I painted. I thought at first that it was supposed to be hull color, but then I noticed in the pictures I got of that area that the conduit appears to be a dull steel color, obviously not painted on the real thing. I tried to duplicate that as best I could.
I know there HAS to be a better/easier way (well, there is, the photo etch part that I ruined), but this sort of worked.
Wow Curt, kudos on your the effort put in on the cable conduit, not a walk in the park indeed.
I will try to replicate mine using cut up plastic sheet.
Once again good job!
