CO2/Nitrogen Source for Airbrushing
TopSmith
KitMaker: 1,742 posts
Armorama: 1,658 posts
Posted: Saturday, January 06, 2018 - 11:11 AM UTC
Iwata might have an adaptor.
MLD
KitMaker: 3,569 posts
Armorama: 2,070 posts
Posted: Sunday, January 07, 2018 - 04:44 AM UTC
I dug out my old compressor and it doesn't work. I don't know what's wrong with it. I bought a nitrogen tank regulator that goes from 0-60psi. One problem; I'm not sure what threads are on the compressor end of the hose. I have Iwata and Paasche. I think the Iwata is 1/4" BSP. I don't know what the Paasche is. I know the regulator has female 1/4" NPT threads. I just need to go from that to the *#@! hose.
I'll report back when I get it all figured out.
This was the sticking point when I switched to CO2 way back when . I went to an auto repair supply house, not an autozone or clone (think the difference between Home Depot and the crusty old dudes at the local no-name hardware store) and brought the parts I needed connecting with me.
Crusty old dude behind the counter hardly batted an eye. He went in the back and came out with a cardboard box full of brass fittings. We fiddled with them for all of 15 sec. and done!
I'm guessing a compressed gas supplier, welding/beverage guys, can provide the same service.
good luck.
Mike
KruppCake
KitMaker: 401 posts
Armorama: 387 posts
Posted: Sunday, January 07, 2018 - 05:10 AM UTC
You can always get a compressor powerful enough to liquify air and then use a fractional distillation column to selectively obtain both carbon dioxide and nitrogen.
120mmSniper
KitMaker: 157 posts
Armorama: 103 posts
Posted: Sunday, January 07, 2018 - 10:34 AM UTC
I came up with a solution, even though it's a bit inelegant. I removed the regulator and all fittings from my old compressor. It and the new Nitrogen regulator both have 1/4" NPT female threads. I just attached that to the new regulator. I'll order a proper NPT to airbrush hose fitting on Monday, but I can try out my new Iwata with the double regulator setup. I have Iwata, Badger and Paasche airbrushes. I'll get adapters for the airbrushes and just keep one hose for them.
I didn't have time for trying it out today.
barrowb98
KitMaker: 119 posts
Armorama: 119 posts
Posted: Sunday, January 07, 2018 - 07:28 PM UTC
I used CO2 for years before recently switching back to a compressor, it can cause some wierdness with acrylic and lacquer paints (it's so cold and dry it sometimes causes them to dry too fast).
A note on fittings, a lot of CO2 regulators have left-hand threads (I had a Norgren that did) so be aware if you go to start changing out fittings.
