Looks like she left one out - hopefully it's not in your stash as well:
Or maybe that was the modeling gods trying to steer us away from the Academy Mk III kit. It probably explains why I have a stack of different Legend turrets for the thing, and even a (gasp) AEF Designs upgrade for it. Yes, it is as bad as you are probably imagining it to be.
"I think that an old kit worths only if one wants to make a quick build, without spending money for aftermarket, and he is happy with this.
If one buys an old cheap model with the idea to bring it up to the level of a modern one by buying aftermarket items, it will cost much more in total than buying a modern kit and build it out of the box." Massimo, I will have to respectfully disagree here. This kit, as with many that have been disparaged far worse, can be made into a very fine build without a whole lot of money. Here are some of the basics: (Note: Many things are being redone at some point, hence missing mud flaps, MG's, etc...)
Work the tow hooks (cut out the recess with a no. 11 blade) and give it a little cast texture. I like to do this with any build that doesn't have them as separate pieces. There's also s trip there with rivets for the mud flaps. Surely bogarted from some other leftover PE fret.
Cut the holes in the sprocket. Newer kits have this feature:
Cut holes in the idlers as well:
MV lenses are not free, but they won't break the bank either. Any kit looks better with them as opposed to painted on lenses:
A few things going on here - 14 gauge needles for the cylindrical mounts on the shovel handle, casting numbers added to the side of the turret, some big towing shackles from some old Soviet donor kit, and bits of Evergreen strip to finish out the mising detail on the sponson hinges:
And a few more things going on here - more cast numbers on top of the turret, stowage bin handles added, and most importantly, bin cover torsion springs, with the associated mounting points. Also note thinned and drilled out Uzi mount:
Another detail the kit missed, but easily added from the spares box - the fuel can rack, used mostly as a place to mount a PRC-77:
I did this kit over twenty years ago, before there was any PE for it that I knew of. A sheet of model railroad PE had just the right pattern, and cost very little. Note also the catch for the driver's hatch at the lower left:
Reworked fire extinguisher handle, And there's an exhaust pipe in there as well. This will certainly get repainted during the refit.
And of course as you've seen throughout, I added non-skid texture. Yes, in spite of what some have said, the Mk I (not just the hybrid) had it. That's why I modeled it.
Again, these are just
basic things you can do to make this kit a keeper.
