Hi all,
Anybody ever try mixing Tamiya Flat clear , with their paint?
Sort of like killing two birds with one stone.
Any adverse effects?
Thanks
Jeff
Mixing Tamiya flat clear with Tamiya Paint
sgtreef
KitMaker: 6,043 posts
Armorama: 4,347 posts
Posted: Monday, February 19, 2018 - 11:48 PM UTC
Tojo72
KitMaker: 4,691 posts
Armorama: 3,509 posts
Posted: Tuesday, February 20, 2018 - 12:09 AM UTC
I believe thats the way its supposed to be used rather then on its own
Posted: Tuesday, February 20, 2018 - 01:21 AM UTC
Jeff,
Tamiya XF-86 Flat Clear is intended to be used as a final flat coat after you have
painted and decaled your model.
Tamiya X-21 Flat Base is intended to be used as a flattening agent, it is mixed into
the X series of paints(gloss), to render them flat.
NEVER use X21 as a final coat as it will make your model totally "white",once dry.
I don't see the reason of mixing Flat Clear into the XF series as this paint is already flat.
Joe
Joe
sgtreef
Posted: Tuesday, February 20, 2018 - 06:29 PM UTC
Jeff,
Joe
Thanks to both, what I am referring to is their Clear flat, and just trying to save a step.
I know about the problems with using their flat base by itself
Just getting a tad lazy maybe.
Think I will try on some scrap plastic first just in case a mess up.
AgentG
KitMaker: 1,109 posts
Armorama: 1,095 posts
Posted: Wednesday, February 21, 2018 - 06:28 AM UTC
Actually, if applying decals, you'd be better off adding some Clear Gloss to the flat paint. That would render a semi gloss finish better able to accommodate decals without silvering. Then flat coat the entire piece.
G
G
sgtreef
Posted: Thursday, February 22, 2018 - 04:25 AM UTC
G
I like that and would be good for applying a wash also.
Thanks.
nzgunnie
KitMaker: 371 posts
Armorama: 174 posts
Posted: Thursday, February 22, 2018 - 11:29 AM UTC
Considering how matt and almost chalky tamiya XF paint can be, I'm not sure why you'd bother mixing XF-86 with it.
I mix X-22 gloss with it. It goes on smoother and removes the dead flat chalky finish. It makes glossing for decals much easier.
Then at the end of the build, I put a flat coat on.
