A bunch of changes with the flat turret, turret basket, formed rear and welded hull all came together at once. So mix ups were bound to happen.
Also things on ranges can lose stuff like turret baskets. Then when it gets put back together for a display it's missing.
Stephen-- The "tunnel" for the drive line is way to high for any turret basket. In addition, the seats for the gunner/TC have frames on either side. It looks like an early M3 with an M3A1 turret, which is what I surmise it is. Probably something they put together from parts as you suggest. On the other hand, the one at the Fort Lewis Museum is pure M3A1 (welded hull, no rivets, rounded rear). The early M3 is just outside the WA National Guard HQ building, about a two miles down I-5 from Fort Lewis, and visible from the freeway. Both the driver and co-driver's view ports are open on that one so you can look right inside the hull, which still has it's original equipment tags in place, and is in pretty good shape considering it's been there about 30 years now at least.
Marc-- After looking at the sprues, Tamiya may be planning on making an early M3, late M3, and an M3A1 (with the rounded rear), since they have the upper hull sides separate As Michael Koenig (165thspc) mentioned. And it appears there are gaps in the upper hull where the different parts could go (for the rivited versions maybe). Let's hope! But the answer to you question is you could probably modify it (I did for a conversion of Tamiya's M5 kit several years ago) however, there is a line of distinctive screws heads on either side of this part and those would be hard to replicate since they are flush mounted with a slot.
VR, Russ
