Sunflower Madness Now I will be the first to confess that I thought I had taken leave of my senses at this point... it all started when I was on holiday in Italy a couple of years ago and we were staying in a villa surrounded by sunflowers. I got it into my head that I wanted a field of them to feature in my diorama.
After a bit of research I discovered these wonderful 1/35 sunflowers in kit form: GreenLine GL085 laser cut sunflower plants.
Now I haven't worked with many paper kits before, but these are absolutely stunning. They are also quite ingenious. And quite time-consuming... Having said that, I believe they are absolutely worth the effort.
The set comes with sheets of flowers and leaves pre-coloured in yellow and green. The leaves are even embossed with the leaf veins in a slightly lighter shade. There's a piece of thicker cardboard for the circular stamen and 14 lengths of flexible brass rod. Everything can be pushed out from the surrounding sheets with a minimum of fuss.
Then the fun begins. The flowers are easy enough to make with five layers + the stamen. The leaves then almost 'clip' onto the brass rod, although they need to be glued in place. I used my new favourite glue: Gorilla Super Glue Gel. This is the first glue I have found that actually doesn't clog just as it promises...
It's important not only to arrange the leaves in a three-dimensional way, but also to give them some shape by bending them over a cocktail stick / end of a paintbrush. This is best done before gluing them in place.
Also, although the kit promises to make you 14 plants, I would advise buying two sets if you want to add more leaves (as I did).
Lastly, I brush painted the brass stems using a mix of Vallejo Uniform Green 70922 and USMC Tank Crew 319 + a little black.
Et voila!
Well, as I say, despite the effort I felt that it was worth it. They look great! Now I just have to work out where to put them all...
