KitMaker: 199 posts
Armorama: 198 posts
Posted: Wednesday, November 07, 2018 - 06:53 AM UTC
Hey guys - looking to repaint a turret I've played around with filters on TOO much
and wondered how I can strip it safely?
Is there a solution to submerse it in that will lift it off without damaging the plastic??
CMOT
Editor-in-ChiefEngland - South West, United Kingdom
KitMaker: 10,954 posts
Armorama: 8,571 posts
Posted: Wednesday, November 07, 2018 - 06:56 AM UTC
What type of paint or finishes are used?
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Wednesday, November 07, 2018 - 07:32 AM UTC
If acrylics, use windex or ammonia to strip.
For enamels, use brake fluid or oven cleaner to strip.
Showcase
KitMaker: 199 posts
Armorama: 198 posts
Posted: Wednesday, November 07, 2018 - 07:47 AM UTC
Stynleres Black primer, Vallejo model air and VMS gloss
KitMaker: 199 posts
Armorama: 198 posts
Posted: Wednesday, November 07, 2018 - 07:48 AM UTC
Is VMS Acrylic?
So soak in windex?
KitMaker: 3,736 posts
Armorama: 3,697 posts
Posted: Wednesday, November 07, 2018 - 11:43 AM UTC
Testors offers a product called Easy Lift-Off that removes paint and decals.
KitMaker: 199 posts
Armorama: 198 posts
Posted: Wednesday, November 07, 2018 - 12:07 PM UTC
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXEVFC This stuff?
So I'm assuming it won't damage the plastic
KitMaker: 1,517 posts
Armorama: 1,109 posts
Posted: Wednesday, November 07, 2018 - 12:15 PM UTC
varanusk
Managing EditorSanta Cruz de Tenerife, Spain / España
KitMaker: 1,288 posts
Armorama: 942 posts
Posted: Wednesday, November 07, 2018 - 09:16 PM UTC
KitMaker: 1,388 posts
Armorama: 1,325 posts
Posted: Thursday, November 08, 2018 - 01:39 AM UTC
I have yet to find a solution that will strip Vallejo Model Air paints off of a model reliably. Luckily, you can strip Stynylrez off of a surface easily using 98% Iso alcohol. Just give it a good, long soak. You may need to do some scrubbing with a stiff brush to remove the last of the bits. You can also use a brush wet with a plastic-safe lacquer thinner (like Tamiya or Mr. Hobby) to remove stubborn bits.
VMS also offers a stripping solution, as does Tamiya. I, however, do not have experience with them.
Best of luck to you. I will admit I have destroyed more models stripping paint than I have saved them.
Modelling is not just a hobby, it's an addiction.
KitMaker: 3,670 posts
Armorama: 2,052 posts
Posted: Thursday, November 08, 2018 - 06:57 AM UTC
Brake fluid, “Easy Off” oven cleaner, and ammonia (not all of them at once!) are the standard go-to paint strippers I use. As someone else suggested, a long soak (a day or two at most) followed by a vigorous brush with a used toothbrush usually does it. Then a final rinse in cool water.
VR, Russ
