I am planning to do is a diorama that is based on a picture from the Valley of Tears, during the Yom Kippur War of 1973. It shows a Syrian tank was left abandoned on one of the Israeli built antitank ditches. A major reference I will use is a 1/35th scale diorama built by Ed Okun. You can check out his work at http://edokunscalemodelingpage.blogspot.com/search?q=tears
For the T-62, I will be using the one supplied in Esci Kit 8615. I have worked on this model previously and it ended up being a shelf queen. The following photos show the work I have done with the T-62.
I've added some AB putty so that there is no overhang in front of the turret. I also added "wiring" for the search light and created MG port from scratch.
I did not like the barrel that came with the kit so I replaced it with brass tubes.
I roughed up the turret surface and added some more details.
I dry fitted a DsHK which was borrowed from Revell T-55.
Both the tracks and road wheels are from Modell Trans Modellbau.
There was not enough tracks to go around the left side so I used the kit supplied ones and added guide teeth.
The driver's hatch is an extra part from the Revell T-55 kit.
This is where I left off and is my starting point for the diorama.
-Joseph
