Very nice model.
Pozdrowienia dla ziomala.
M151A1 finished - photos
jw73
KitMaker: 148 posts
Posted: Wednesday, May 26, 2004 - 03:07 PM UTC
Posted: Wednesday, May 26, 2004 - 04:12 PM UTC
Wow! It looks fantastic! So real...my wife was looking over my shoulder and said, "if you hadn't told me it was a model, I would have thought it was real." Awesome job...I hope mine turns out half as good...when I get around to building it that is...
Vodnik
KitMaker: 4,342 posts
Armorama: 3,938 posts
Posted: Wednesday, May 26, 2004 - 08:02 PM UTC
The M-4 pedestal machine gun mount, as mounted in the M151-series vehicles, consists of the upright post that is bolted to a single-piece bracket that resembles an inverted "U" that is squared-off. This piece was approximately 10-12 inches high and 8-10 inches across. The post bolted to the flat top of this piece. The two trail legs or braces are replicated nicely on the model, even adding the small handle that served to tighten the top portion of the post to the main upright.
I was aware that the kit part for the gun mount post support plate is not accurate, but photos I had didn't show this area clearly, so I decided to use it anyway - actually this is the only part of the original kit pedestal I used - everything else is scratchbuilt.
Regarding the tow pintle bracket: The M151 and M151A1 vehicles used tow shackles that were mounted under the rear "bumperettes". These were the same shackles as were mounted on all of the series front bumpers, and the rear ones were for hooking the trailer chains to when towing the 1/4 ton M416 trailers. With the M151A2, the plate with two holes that is portrayed on the Tamiya and Academy models is correct.
Once again you are absolutely right and this time I admit I made a mistake! I didn't notice the difference in tow pintle configuration between A1 and A2 variants. But it is easy to correct - I will remove the plate with holes and add missing shackles under bumperettes. Easy job!
I live in the LA area, would be great to have the chance to meet the creator of some very fine models.
But I just came back to Poland three days ago... What a pity! Maybe next time!
Pawel
lestweforget
KitMaker: 2,832 posts
Armorama: 1,500 posts
Posted: Wednesday, May 26, 2004 - 08:11 PM UTC
Great Job, who doesnt like these little buety's?
i like the little radio! and great weathering and paint work.
cheers
cheers
