I agree that stirring introduces too much air into the mix.... I use a deep spinning paint stirrer... all the aggitation is down deep, so little if any air is brought in from the surface of the liquid, as would be if you used a typical stir stick. Also, you might consider after stirring, to suck the fluid into a clear squeeze tube... you can then hold the bottle upright, and tap several times, which makes most bubbles rise. Squeeze the bottle, and they escape from the top (just like doctors do with a syringe). Now turn over the bottle (still squeezed, and gentle apply more pressure... this will cause a bubble-free stream to come out and lay flat. Also, make sure your surface is TOTALLY dust free before pouring. Finally, use a hot air hair dryer to keep the liquid from setting too fast if you see bubbles have formed. The longer it stays liquid, the more time the bubbles have to escape. - Keith
