Dioramas
making cobblestone
Mech-Maniac
KitMaker: 2,240 posts
Armorama: 1,319 posts
Posted: Wednesday, September 22, 2004 - 07:21 AM UTC
do you guys make your cobblestone streets or order them? if you make them, with what and how? i'm starting a rather large dio here in a month or 2 and dont wanna spend anymore money then i have too
PLMP110
Alabama, United States
KitMaker: 1,318 posts
Armorama: 837 posts
Posted: Wednesday, September 22, 2004 - 07:23 AM UTC
I had good results following a thread here on using Lentils. It is a bit tedious, but so very inexpensive. Just glue them down, "grout" them with wall spackle, and paint. Pretty easy.
Patrick
Mech-Maniac
Posted: Wednesday, September 22, 2004 - 07:27 AM UTC
what are Lentils?
Kharkiv, Ukraine / Україна
KitMaker: 705 posts
Well, I'm in the process of making my first building ruins and I made the brick walls for it myself. Since bricks are very similar to cobblestones, they can be made with this method too.
I rolled out a large amount of Sculpey into a flat sheet and baked it as per instructions. then I simply scribed in the bricks with a dull X-Acto blade. The clay is kind of soft after it was baked so scribing was very easy. I am satisfied with the result, however it does take up a lot of time. So, for a large dio, you might want to consider buying a premade sheet.
Another option would be to try the cork method: https://armorama.kitmaker.net//features/205
Minuteman
KitMaker: 261 posts
Posted: Wednesday, September 22, 2004 - 07:33 AM UTC
I have used spakle and drywall compound and have had pretty good results. I have seen the work others have done with lentils and it looks great but I have never had much luck with them.
Mech-Maniac
Posted: Wednesday, September 22, 2004 - 08:09 AM UTC
thanks for all the good tips! but yes, since i am doing a rather large dio i just might buy a large sheet, wheres the cheapest i can find?
Marty
Massachusetts, United States
KitMaker: 2,312 posts
Armorama: 1,054 posts
Posted: Wednesday, September 22, 2004 - 08:25 AM UTC
You could also make your base out of plaster and scribe the cobblestones. This is one of the techniques I use.
PLMP110
Armorama: 837 posts
Posted: Wednesday, September 22, 2004 - 08:31 AM UTC
If you are going with the large sheet, take a look here. I'm sure he will hook you up.
Patrick
Neill
KitMaker: 1,255 posts
Armorama: 485 posts
Posted: Wednesday, September 22, 2004 - 08:40 AM UTC
I make my own, here is an article on buildings that include making cobble stone.
Basic Building
and I also use split peas for this one
John
www.johnneill.com
slodder
KitMaker: 11,718 posts
Armorama: 7,138 posts
Posted: Wednesday, September 22, 2004 - 08:53 AM UTC
So many ways
you can take what faust did on the walls and go to the ground in
https://armorama.kitmaker.net//features/142
or
Cork it (as mentioned)
or
lentling it (as mentioned)
https://armorama.kitmaker.net//features/315
or
scratching
https://armorama.kitmaker.net//features/393
or
take what Marty did on the walls and go horizontally
https://armorama.kitmaker.net//features/389
or more cork
https://armorama.kitmaker.net//features/397
or you can buy some
https://armorama.kitmaker.net/review/493
Art
Michigan, United States
KitMaker: 604 posts
Armorama: 318 posts
Posted: Wednesday, September 22, 2004 - 10:27 AM UTC
You got a lot of good responses, but I just gotta toss in my favorite-drywall ( you can probably pick up enough for your whole dio free, either at a construction site, or check Home Depot, etc. for any broken sheets they discard). Soak in hot water to loosen the glue, scrape off the cardboard (if you're doing a street, just scrape one side), then when dry, carve in the cobbles and round them off with a small wire brush. If you want sidewalks, just use a putty knife and scrape the plaster down to the depth you want.
Art
Mech-Maniac
Posted: Thursday, September 23, 2004 - 04:04 AM UTC
thanks all
art- i use drywall for construction of a lot of my buildings, the drywall wont blend the street and buildings together will it (because its the same material)
Art
KitMaker: 604 posts
Armorama: 318 posts
Posted: Thursday, September 23, 2004 - 08:54 PM UTC
I use it for both streets and buildings. You probably already know this, but the way you weather it (pastels, paint, wash, etc.) determines wether or not they match. Also, because of the way the plaster takes the weathering, you pretty much have to work at it to get it to match anyway.
Art
