West-Vlaaderen, Belgium
KitMaker: 10 posts
Posted: Saturday, January 01, 2005 - 04:34 AM UTC
Singapore / 新加坡
KitMaker: 1,041 posts
Armorama: 533 posts
Posted: Saturday, January 01, 2005 - 04:37 AM UTC
hello Janssens
welcome to the big A !
and...even though you are new here....you sure arent new to modelling! That is one great diorama!!!..
the ice is great and everything else..how did you do tthe ice?
Pig #126. Lord of Mental Institute, Minister of Chewing Gums
A self confessed Panther-holic
Michigan, United States
KitMaker: 5,409 posts
Armorama: 3,777 posts
Excellent dio. I just recently completed a Tiger and always great to see other Tiger builds. Can you give some details on what you did?
You don't support the troops if you don't support the mission!
KitMaker: 2,240 posts
Armorama: 1,319 posts
Posted: Saturday, January 01, 2005 - 05:07 AM UTC
excellent diorama! the ice is really nice
KitMaker: 4,307 posts
Armorama: 2,130 posts
Posted: Saturday, January 01, 2005 - 06:21 AM UTC
That is one spectacular diorama. I guess the ice is wax? over resin?
Great detail - even the spray of water/snow coming off the front of the tracks
Bulldog#3
Grumpy Old Modeller No1
Growing old disgracefully!
Kobenhavn, Denmark
KitMaker: 6,760 posts
Armorama: 1,339 posts
Posted: Saturday, January 01, 2005 - 06:32 AM UTC
Fantastic dio. The ice and water is awesome.
What do you use for ice?
On the workbench:
MPC: 1972 Pontiac GTO
Revell: 1965 Mustang
Verlinden 120mm guard of the marine.
Revell: 2010 Camaro
Monogram: 1931 Rolls Royce
Italeri: LVT2 Amtrac
betheyn
Senior Editor
#019
KitMaker: 4,560 posts
Armorama: 510 posts
Posted: Saturday, January 01, 2005 - 06:43 AM UTC
Fantastic dio, i had to put a coat on, just looking at it made me feel cold. :-) . You will have to tell us how you did the water and ice,as they look real good. :-) :-)
It's not the same, better, but not the same...
Zuid-Holland, Netherlands
KitMaker: 4,808 posts
Armorama: 1,069 posts
Amazing, I like the ice.
Same question as the others, how did you make the ice?
My question, how did you make the rain stripes??
Also I love the fuel drums at the back of the tank.
BTW welcome to Armorama!
KitMaker: 10 posts
Posted: Saturday, January 01, 2005 - 06:46 AM UTC
thanks mates for the response ok here goes, shall start from the beginning:
first took a cheesboard(hardwood) and cut all the way trough a halfcircle out of it and siliconed - screwed a thinner piece on the underside so you make a halfcircle basin in your board ( take care the basin is watertight ) next step when you finished making your bank ( sloping : land-water) is to maske off the place were your piece of armour is suppose to come, i've just used a piece of cardboard and painterstape for that. next i've brushed the hole area were the ice is with a mix of 50/50 white gleu/ water (about 3 coates) to seal eveything, now paint the bottom of yous river or stream with dark green-brown (just play around abit with colours ) and lighten it up to the bank,used enamels for that. the ice is just paraffin wax heated so it flows like water (thats why everything must be watertight ).when that hardens just remove your masking and clean it up a bit were your tank sits. now take a thick needle and scrape some cracks in your parrafin to simulate the strain the ice is under of the weight of your tank. now i'll brushed one layer on the ice with gloss gel medium from LIGUITEX so you get a oneven apperence of ice. when that's all dry gleu your tank to the base and poor in thin layers clear polyester resin around , on the 3 layer put some flat broken pieces of parrafin in your resin so it float in between layers . on the last coat of resin just play with it a bit with a toothpick to get some ripples.almost done, now when dry i've brushed several layer on the resin with gloss medium ( just let it dry between layers but if you wand some white wavetops build it up thicker, it's stays white then).
and the snow is just your basic groundwork with broken leaves then brushed a thick layer with a mix of baking soda-white gleu-water and when dry sprayed a mist with white gleu and water and fine sprinkled from above a light coat of pure baking soda.
well i'll hope it will help somebody to take a leap in making suth thing , it was a pleasure for me to make it , ohhhh Sorry for my english
LUC.
KitMaker: 1,185 posts
Armorama: 810 posts
Posted: Saturday, January 01, 2005 - 06:56 AM UTC
Maffen -
Welcome to Armorama and I'm sure you'll enjoy be part of this fantasic modeling "family". From the looks of that outstanding diorama, I know we'll be looking forward to and enjoying your builds and inputs. Very, very nice work and one of the best, most convincing "winter" scenes I've seen in awhile. I especially like the Tank Crew, definitely looks like they're wrapped for the conditions. Most definitely looking forward to more of your work. Take a look at the "Campaigns" running. You've got the "winter" idea well in hand and would make a great "Ardennes" participant. Again welcome aboard,
Blade48mrd
"With your shield or dead upon it!"
KitMaker: 1,933 posts
Armorama: 985 posts
Posted: Saturday, January 01, 2005 - 07:12 AM UTC
Man that looks cold, I like this a lot, the movement in the water is very good. my congratulations and welcome to the big "A"
Rhode Island, United States
KitMaker: 833 posts
Armorama: 601 posts
Posted: Saturday, January 01, 2005 - 07:39 AM UTC
Oustanding Maffen! I particularly like the ice/water effects and the pill box.
----Nothing is "idiot proof" because they will always build a better idiot.------
----Never try to teach a pig to whistle. It wastes your time and it annoys the pig.----
Aarhus, Denmark
KitMaker: 150 posts
Armorama: 36 posts
Posted: Saturday, January 01, 2005 - 08:06 AM UTC
cool dio
it tells a story.
Utrecht, Netherlands
KitMaker: 386 posts
Posted: Saturday, January 01, 2005 - 11:01 AM UTC
only one word FANTASTIC.
the ice, the snow, the tiger and figures just SUPERB!
Greetz Rob!
"We shall fight on the beaches. We shall fight on the landing grounds. We shall fight in the fields, and in the streets, we shall fight in the hills. We shall never surrender!"
(Winston Churchill)
Nebraska, United States
KitMaker: 2,394 posts
Armorama: 1,695 posts
Posted: Saturday, January 01, 2005 - 11:21 AM UTC
Maffen, Amazing work!!! This scene looks real. You have a masterful hand with creating the water and ice. My hat is off to you. Cheers Kevin
Delaware, United States
KitMaker: 1,281 posts
Armorama: 336 posts
Posted: Saturday, January 01, 2005 - 11:46 AM UTC
A big welcome to the big A what a great dio immaganative and all brought together with first class modling skills keep them comming the water is fantastic put my gloves on to write this lol lol
Cheers chris tango 20
'Gwell Angau na Chywilydd '-' Death rather than Dishonour'
Cheers Chris
Rheinland-Pfalz, Germany
KitMaker: 202 posts
Posted: Saturday, January 01, 2005 - 11:53 AM UTC
Great looking dio Janssens! The broken ice is not something you see very often. Welcome to Armorama
Pig #131 Das Deutsche Schwein
"Be strong sayeth my heart, for I am a soldier, and have seen worse sights than these."
-Odysseus
Rio Grande do Sul, Brazil
KitMaker: 416 posts
Posted: Saturday, January 01, 2005 - 12:40 PM UTC
Hi and welcome Janssens,
I know I'll say the same things that everybody already said, but I can't be without speaking anything.
So, wow! Man, that great way to introduce yourself!
I'm here sweating a lot, and your dio gave me a fresh sensation. I'm very impressed with the water being slippery of the tank, the broken ice and the frozen face of the crew member at the right hatch.
Congratulations.
To drive a Jeep is good because is bad, it would be better if it went worse!!!
#099
Indiana, United States
KitMaker: 926 posts
Armorama: 383 posts
Posted: Saturday, January 01, 2005 - 02:57 PM UTC
A truely spectacular dio! Very convincing ice and it sure gives the apearance of being very cold....not an easy thing to capture in a dio IMHO! Thanks so much for sharing your work and the technique used for making the ice and water...great work!!
Minnesota, United States
KitMaker: 437 posts
Armorama: 292 posts
Posted: Saturday, January 01, 2005 - 04:09 PM UTC
Maffen,
that is one awesome dio. I'm starting to shiver with cold just lookin' at it. Welcome to Armorama, you have great skill!
"When war does come, my advice is to draw the sword and throw away the scabbard". General Thomas "Stonewall" Jackson
Wisconsin, United States
KitMaker: 1,864 posts
Armorama: 727 posts
Posted: Saturday, January 01, 2005 - 04:53 PM UTC
What more can I say that everybody hasn't! Excellant job! And welcome.
~Chip
Exercising My First Amendment
Free Country Man!
KitMaker: 347 posts
Armorama: 167 posts
Posted: Sunday, January 02, 2005 - 02:44 AM UTC
Welcome and Happy New Year!
I think the ice and water effects are great. I think a great dio illustrates a story or feeling and this one does the job. I can almost see feel the steam rising from the broken ice as the heat from the tank meets the water!
The figures aren't too shabby either.
I have yet to try any water effect but I sure am enthused by the result you achieved.
Happy New Year,
Michael
KitMaker: 10 posts
Posted: Sunday, January 02, 2005 - 05:18 AM UTC
thanks mates for your comments
Quebec, Canada
KitMaker: 2,412 posts
Armorama: 1,174 posts
Posted: Sunday, January 02, 2005 - 01:46 PM UTC
awsome job on hte ice and snow and the overal dio itself, great idea! one thing on your fourth pic, the water, it looks liek sea water to me, not a river, and i doubt that tiger can swim
maybe could have added some sand or earth, soemthing to make the river bed look more realistic, or simple paint it with an "earth" color to simulate the mud lifted by the tank as it crosses the river
Frank
GREAT DIO!
"The problem with the french is that they don't have a word for entreupreuneur"
George W.Bush
KitMaker: 123 posts
Posted: Sunday, January 02, 2005 - 02:04 PM UTC
GREAT DIO
the ice is excellent and love the cold look on the figures faces.
