Angela,
If the plaster mix-or joint compound-is cracking, you are probably laying it on too thick. Try using a couple of thin coats rather than one thick coat. This should also prevent it from shrinking.
Cobblestones Again
Parks20
KitMaker: 737 posts
Posted: Friday, February 11, 2005 - 01:27 AM UTC
PvtParts
KitMaker: 1,876 posts
Armorama: 1,120 posts
Posted: Friday, February 11, 2005 - 11:23 AM UTC
Angela, Small trick you can try with the Plaster is add dish soap..It works with spackle. What it does is slow down the dry time. I have never tried it with plaster but see no reason it wont work..Experiment with small batches.
warthog
KitMaker: 1,460 posts
Armorama: 1,080 posts
Posted: Saturday, February 12, 2005 - 08:17 PM UTC
Angela: I have not experienced the cracking of wall putty or spackle. I usally apply wall putty with several thin layers. I allow the first layer to dry first before applying the second layer. After applying putty, I normally brush it using an old brush with some water.....What brand do you use?
Angela
KitMaker: 853 posts
Armorama: 514 posts
Posted: Sunday, February 13, 2005 - 04:37 AM UTC
Hello,
Thanks for all the input guys. I think I know what to do now.
Warthog, I used what you recommended....Bosny's Wall Putty.
Angela
Angela
warthog
Posted: Monday, February 14, 2005 - 01:00 AM UTC
Angela: Oh, I use Bostik not Bosny. Although I've seen that brand, I have never exprienced using it. The other brand I used was RJ -- it has a rubbery finish that's why I don't use it anymore.
I'm sorry if ever I gave you the wrong suggestion, they do sound the same...
Angela
KitMaker: 853 posts
Armorama: 514 posts
Posted: Tuesday, March 29, 2005 - 02:28 PM UTC
Hi guys,
Thank you so much for the inputs and suggestions. I've made my cobblestone street. I used wall putty (spackle) to cover my foamboard street. When it was dry, I scribed a pattern. I had some minute errors on the length and width of the bricks but they look okay. Besides, I think that due to repairs, destruction and wear and tear, the cobblestones have different sizes.
One more translation needed.
My scene of my diorama is Bastogne. How do you say "Library" there?
Thank you.
Angela
Thank you.
Angela
Florre
KitMaker: 980 posts
Armorama: 158 posts
Posted: Saturday, April 02, 2005 - 03:06 AM UTC
That's "bibliothèque"
Angela
KitMaker: 853 posts
Armorama: 514 posts
Posted: Wednesday, April 06, 2005 - 08:02 PM UTC
Aaahhh....
Thank you very much, Hans.
Angela
Angela
