Constructive Feedback
Grumpy's doing a "Sherman"
ShermiesRule
KitMaker: 5,409 posts
Armorama: 3,777 posts
Posted: Tuesday, July 26, 2005 - 08:09 AM UTC
What periscope set did you use?
Red4
KitMaker: 4,287 posts
Armorama: 1,867 posts
Posted: Tuesday, July 26, 2005 - 10:06 AM UTC
They look scratched to me. Nice work thus far. "Q"
Grumpyoldman
KitMaker: 15,338 posts
Armorama: 7,297 posts
Posted: Tuesday, July 26, 2005 - 10:41 AM UTC
Thanks Bear... didn't know that...... learned something new....
and another little detail to add.......
Alan, Matthew is correct, I scratchbuilt them.
Grumpyoldman
Posted: Tuesday, July 26, 2005 - 11:32 PM UTC
OK, made the open periscopes last night. I replaced the inside ones, to line up with the outside ones, to point in different directions, for a more casual look.
Off until Friday night, so no more work or up dates until the week end.
Prato
KitMaker: 1,002 posts
Armorama: 720 posts
Posted: Friday, July 29, 2005 - 08:29 AM UTC
It looks fantastic! Keep up the good work!
Cheers and happy modelling!
Prato
Prato
Grumpyoldman
Posted: Monday, August 01, 2005 - 05:48 AM UTC
Another Monday, another update.... :-) :-)
I added the kit tools, first I removed most of the molded brackets, and replaced with slivers of lead foil, I also used lead foil for the straps and buckles.
I added the little tie downs along the rear shelf. The photo showed a lot, so I added a lot. No I didn't count how many, feel free to count.... weren't that hard to make, simplely put down tiny slivers of .10 rod, let it dry over night, and then added .10 rod over the bottom ones, let dry over night, and trimmed off the excess.
Did the periscope guards, still have the one remaining turret one to do. Really wasn't that hard. I used some old stripped aluminum electical wire that was laying around the scrap bin at work. straighten under a rolling steel ruler.
I drilled two shallow holes on each end, being carful not to drill all the way through, bent the wire to shape, (yep took several times for each, CAed in place, let dry, gently bent each outwards a little, and cut the cross pieces to fit, and CAed in place. (yep, took several tries for each). But really nothing beyond the average modellers skills. (I only consider myself an average modeller by the way)
Grumpyoldman
Posted: Tuesday, August 09, 2005 - 04:25 AM UTC
OK, another update..... did a little work on it last night, (was busy over the week end doing my "on 2 wheels campiagn" piece)
Made up the headlight guards last night. Really were not that hard to do, actually a lot easier than I imagined.
I simply took a piece of masking tape and applied it to one of the kit guards, then held it up to the light, and traced the shape.
I then removed the tape, and put it on a thick piece of plastic sheet, and cut it out, only doing the forward edge. A little gentle sanding to try to even it out. I then placed this template on a sheet of .10 plastic, scribed the forward edge, then slid the template rearwards a little, and scribed the rear edge. Then I simply cut the piece out, curled it over a piece of tube, and glued in place. I added the braces, and cross pieces from some .10 plastic strip. (Headlight guards still need to be trimed) Total time was about two hours, most to make up the template.
Maybe not perfect, but hey, I made them....... and for me that's the fun part. :-) :-)
USArmy2534
KitMaker: 2,716 posts
Armorama: 1,864 posts
Posted: Tuesday, August 09, 2005 - 04:56 AM UTC
But not bad either! If you think they are, consider them "in the field replacements!" Following this has been a lot of fun and an exercise in simplicity of model building.
Jeff
Grumpyoldman
Posted: Tuesday, August 09, 2005 - 07:13 AM UTC
Thanks Jeff.... so far it has been fun.
TsunamiBomb
KitMaker: 1,447 posts
Posted: Tuesday, August 09, 2005 - 07:52 AM UTC
Looking Excellent Grumps, I really hope to be seeing this in some sort of diorama!
Grumpyoldman
Posted: Tuesday, August 09, 2005 - 12:45 PM UTC
Harrison, after I finish the vehicle, I'll carefully pack it and send it to you, so you can work your magic on it for a diorama..... :-)
HONEYCUT
KitMaker: 4,002 posts
Armorama: 2,947 posts
Posted: Friday, September 23, 2005 - 10:09 PM UTC
So what happened Dave!?!?!
Is it still in the works? This peaks my interest more than most, as it is a near step by step of the somewhat painstaking process I follow to get a Sherman 'up and running'... Including the hiatus it seems you have encountered :-) :-)
Brad
P.S. with all my banging on, I forgot to mention that it is looking great! As an alternative to plastic for the headlight guards, I use flat lengths of brass, .015"X.042" from my local model train shop.
Brad
Grumpyoldman
Posted: Friday, September 23, 2005 - 10:23 PM UTC
:-) Update will be coming in a new thread....
Need the experts to check it over before the primer.... :-)
husky1943
KitMaker: 1,305 posts
Armorama: 591 posts
Posted: Saturday, September 24, 2005 - 09:40 AM UTC
Ciao Dave,
Looking good so far! Keep us posted on this future masterpiece!!
Ciao for now
Rob
Ciao for now
Rob
jazza
KitMaker: 2,709 posts
Armorama: 1,818 posts
Posted: Saturday, September 24, 2005 - 10:09 AM UTC
Hi Dave,
This is a great thread and i do hope you keep it going!
Its really perfect how you are documenting it step by step.
If you ended up consolidating all this information in a document, it would be perfect as amatuer modellers like myself can see how you scratch build the little parts.
Could you please also explain how you textured the bulge on the turret? I noticed that you applied this same method along the panels and am really curious how it would turn out.
