Ola Guys
Thanks for the replies.
@ Alan
Wow Faust! You really like those 37mm. DIdn't you do the one where the Germans in a captured jeep are towing a 37mm and the rusting away 37mm being dug up?
Alan you have a Damn sharp eye. Yes I did the 37 Mm PAK being hooked up on an Airborne Jeep during the battel of arnhem. And yes I was the one resposible for the rusted up PAK that is being dugged out during a Archeoligical search. The Archeological search never was completed because I made a stupid mistake in the makings of the groundwork. ( an extra layer was to be added as the gun was sticking out of the ground) I have an extra 37 MM laying around with which I`m still planning to finish the excavation as the dio was simply to good to let die. the Rusted out PAk eventually ended up in a small display called
So yeah the outcome of the thing is I really love the 37 mm PAK. The one being towed behind the BMW is the 4th one as I also did a conversion of the DML Sd.Kfz. 251/10 in Polish service with the 37mm Gun on top of it.
I have another 37 MM PAK from DML laying around which will fill the hole in the excavation.
@Cheyenne
The Tamiya bike is a dog kit but you dressed it up nice.
Try the Italeri kit, compared to the Tamiya one it beats it hands down.
I secod that. I have built the Italeri kit before which went into a littlle display called "Raspoetitsa" and the bike was miles and miles away from the quality that Mr. T is offering.
This is where the Italri BMW with sidecar ended
I only added brakecables to the Italeri one as the rest was already there
@ Scott
I saw this and just knew you had found another gem of a photo - nice.
You know me and I`m always looking for that one extraordinary thing to make
The edges of the sadle bags look a bit white and sharp, maybe a touch of sandpaper is needed? Could be the lighting.
Actually that is part of the addition I made. Because the saddlebags are hollow from the backside I added paper to make it closed. What you see is the edge of the paper. When all is painted it won`t be that evident anymore
For all the others thanks for the comments. And mister mcCuhail thanks for the story. Cya all at the endline
