Adam, the most likely used around Normandy, would be the type M1A2.
I'm going to first go for just removing the steps towards the breech. I'll sand them at least to a taper first, than go for straightening taper. Never tried with this barrel before...
Kenc--Are you sure that the Rubio barrel is correct? I know that the Italeri barrel is way off, but I thought that not only is it incorrectly shaped, but that it is too short which would mean that the Rubio barrel is even shorter still.
