How do you attach the PE to plastic so clean? Unlike mine where I often super glue the PE to my figures... What's your secret??
Great job... BTW, Love the DUKW
Thanks WC,
Attaching PE is not that difficult, just remember a few basics,
Don't apply glue directly from the tube/bottle.... put a small drop on a smooth surface, such as an old excacto blade or a CD, and use a needle or tooth pick to apply the glue. For really small parts, use thicker CA glue, pick the part up with tweezers, carefully touch it to the glue, position on the model. Leave a second for it to key, then with thin, runny CA, pick some up with needle, toothpick or such and touch the mating surface of part and model. Copila...capali... capilary action will draw the glue where it should go.
Tweezer and exacto blades where invented for a reason. Use them instead of your fingers. I don't touch PE parts with my fingers at all when glueing them.
Good luck
Henk
