I have a question which I hope you may see and answer as to how you produced the road surface that looks so realistic. One of my ongoing projects needs a strip of road and I am lost at how to make it?
John, Thanks. Glad you like it. Your question has come up a couple time. From page one of the post.
"HeavyArty's Dio Building 101:
The wooden base was made by me as well. It is a 1" x 10" piece of pine, cut to size, routed the edges, and finished with stain and an acrylic clearcoat. The wall is a piece of 3/8" plywood sunk into the base in a routered channel. The sidewalk is a piece of artists foamcore board to raise it up above street level. The whole thing is covered with Spackling Compound, plaster used on drywall, and smoothed out with a putty knife. First, the wood is roughed up with a sanding disk to give the palster something to hold onto.Once dry, I further smoothed it with sand paper. It was all then painted with enamels, and weathered with acrylics, enamels, and pastel chalks."
Hope that helps and good luck on yours.
