Thank you very much for your answers.
One other note, if you are doing an ODS ('90-'91) HMMWV, the sleeping bags you have on the back, from the Tamiya set, are incorrect. The Goretex style wasn't issued till mid '90s.
I understand and thank you for correcting my mistake. And what about using folding beds, MRE cartons and binoculars from Tamiya Modern U.S. Military Equipment Set, as an ODS items?
Thank You Pete for your links. It will be very helpful.
I might suggest using some kind of a filler or styrene sheets to cover up that hole on the bonnet closer to the exhaust stack.
This hole is an effect of my accident with hair-dryer.
Here is a better shot of this damage:
Of course I'll try to fix it.
Also the TOW Missle frame is missing a bar on top to stop the upper most TOW missle from rolling off the frame.
It's because I must first add stripes to TOW missiles, then I glue bars.
This looks like the Italeri kit?
Yes it's Italeri model No. 247 (named incorrect as M998 Hummer) but I also used sprue F from Academy kit No. 1363 (M966 TOW Missile Carrier).
I hope you understand what I writing.
