Hi
I'm planning on making a 2 man troop carrier/cargo version of a Humvee from Desert Storm 1991 based on a picture on pages 120/121 of Victory In ther Gulf from Windrow and Green.
The vehicle has a an M60 mounted in the cargo bed directly behind the cab.
Any ideas as to how that would have been mounted - a pole bolted directly to the floor? It's obvipusly a field modification.
I'm using the Tamiya kit with the Calibre 35 conversion kit.
Any help would be appreciated
cheers
Rob
Humvee M998 question
RobH
KitMaker: 352 posts
Armorama: 238 posts
Posted: Monday, April 03, 2006 - 12:01 AM UTC
troubble27
KitMaker: 783 posts
Armorama: 637 posts
Posted: Monday, April 03, 2006 - 01:03 AM UTC
I cant remember the source, but I built the same model about 2 years ago, and was looking for the same thing. Someone on here told me the mount for the M60 was taken from an old Ford Mutt. I had an old m151 pole in the scrap box and used it, and when compared to pictures, it looked about right. So, thats my best suggestion. Hope that helps
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Monday, April 03, 2006 - 01:21 AM UTC
The MUTT pole would work. You could also make your own using a piece of tubing, a square of styrene for the base, with triangular braces coming up the pole. Bolt it down and you are set. You would still need an M60 pintle mount from the MUTT or another model that has one.
USArmy2534
KitMaker: 2,716 posts
Armorama: 1,864 posts
Posted: Monday, April 03, 2006 - 01:38 AM UTC
These two pictures kind of show what Gino is saying, despite this mount being for a Mk-19. Hope this helps.
Jeff
Jeff
RobH
KitMaker: 352 posts
Armorama: 238 posts
Posted: Monday, April 03, 2006 - 02:15 AM UTC
thanks folks.....that was just what I needed!!! I've got a MUTT somewhere - I'll definately check that out!
thanks again for your responses
R
R
Cookie
KitMaker: 588 posts
Armorama: 490 posts
Posted: Monday, April 03, 2006 - 02:18 AM UTC
Rob
The Academy M998 I.E.D. Gun Truck might have what your after.
Cookie
Cookie
