This is the Emhar 1/35 Whippet. I've used selected parts from the Airwaves PE set, like the pistol ports, and handles. I decided not to replace the engine air intake with those provided in the PE set - reason being they looked alot smaller than the plastic molded ones... okay, and they are a dog to put together. Also, I used neither the kit track guard brackets or the PE ones as the Whippet I'm trying to model didn't have them fitted in the 1920's.
In terms of painting and weathering I'm following a method laid out by Mark Bannerman in an old edition of Military Modelling.
So far I've primed the vehicle with Tamiya white primer (from an aerosol). Next was dirt texturing, so once dry I applied liquid glue to selected areas and sprinkled some fine model ground cover (Mark used ground Sage - I'd rather cook with that
The next step will be to apply 2-3 thin coats of flat black to the vehicle, firstly to seal the dirt texturing, and secondly to apply a preshade.
One thing I can say, is that photographing a model certainly does give you a different view of it... suddenly I see a lot more things that need to be filed down...
Well? Is there hope for me yet as an armour modeller? :-)
Don't worry figure guys... I'm not jumping ship, just trying something different for a change :-) :-)
Rudi
