Hopefully I get it ready for painting by to morrow.
Erik
The M2's used on M1's and M1A1's wouldn't have the sites or charging handel on them.
...but if the MCD is attached and uncovered, the smoke grenade system would have live rounds in them, not the rubber dust covers.
Also, is the hull top attached at the rear?
Shame on me, I just realized I have become an Abrams rivet counter.
...you may need to add the NATO socket that is missing on Legend's APU
With the dazzler in use, I assume this will be OIF1 or not too far after. What markings will this model sport?
...but how are you planning to paint the hull, wheels and tracks now that have been glued together?
YOU HAVE THIS WRONG, THAT WRONG, THIS IS NOT RIGHT AND THAT DOESN'T GO THERE, OH, AND THAT THIRD BOLT AN THE LEFT UPPER RIGHT OF THE SOO AND SO DOESN'T BELONG THERE AND THAT 4TH BOLT NEEDS TO BE MOVED 2 INCHES TO THE LEFT........!!!!!!!!
ARE THOSE TURNED ALUMINUM ANTENNA MOUNTS AND IF SO, WHERE DID YOU GET THEM?
Which Dragon kit did you use as a base (is it the 3531)? I'm guessing the extra rack on the back of the turret is coming from the Academy M1A1 OIF?
What paint are you going to us for it?
One quick question--will you be taking the final section of the side skirts off of both sides, or just the left one?
I can't even begin to live up to what you've done.
Ok Erik, since you don't mind the "Rivet Counting", her goes my rant!
YOU HAVE THIS WRONG, THAT WRONG, THIS IS NOT RIGHT AND THAT DOESN'T GO THERE, OH, AND THAT THIRD BOLT AN THE LEFT UPPER RIGHT OF THE SOO AND SO DOESN'T BELONG THERE AND THAT 4TH BOLT NEEDS TO BE MOVED 2 INCHES TO THE LEFT........!!!!!!!! :-) :-) :-) :-) :-) :-) :-) :-)
Seriously, it's a good start Erik.
You just couldn't wait for the new DRAGON AIM to come out, had to build a Abrams....
