BTW, what's good to use to portray scale power lines?
Italian Farmhouse Update
Delta42
KitMaker: 616 posts
Armorama: 511 posts
Posted: Friday, September 22, 2006 - 08:54 PM UTC
As I promised months ago, here are the latest photo's of this project. most of the weathering is finished, but i still have some small details and rubble to add. as always, your comments are welcome.
roudeleiw
KitMaker: 2,406 posts
Armorama: 2,224 posts
Posted: Saturday, September 23, 2006 - 02:24 AM UTC
This looks really good, a lot of special ideas in your house.
I really love your stairs, great touch and good execution . Let them run outside the viewfield and than come back, exactly what i am planning to do myself actually. The only little problem i see is that you have only 7 steps (oh yes, we see everything) to lead up, so thats at least 30 cm per step.
I also like your painting style. It looks Italian :-)
Do you have plans for furniture to put in there ?
Is this going to be a complete dio ?
Claude
Claude
HONEYCUT
KitMaker: 4,002 posts
Armorama: 2,947 posts
Posted: Saturday, September 23, 2006 - 04:11 AM UTC
Gday Dave!
Really nice subtle colours used here, and they complement each other greatly
If I was to have a nitpick, it would be on the rust(?) below each window shutter. It seems to be too vibrant, and uniform? Maybe blend them in a little more on the rear side...
The down pipes are a nice touch. Are you going to have a barrel or drum under the bottom outlet?
As for scale wire, you can use copper wire from an old electrical cord/cable... They have difffering sizes, so you can scout for the one that suits!
Great job
Brad
Great job
Brad
Delta42
KitMaker: 616 posts
Armorama: 511 posts
Posted: Saturday, September 23, 2006 - 09:10 AM UTC
Thanks for the comments.
Claude
Not planning on any furnature to any extent. I may have one or two broken pieces, but not much as I just will fill most of the interior with rubble. the house is going to be the backdrop in my T-19 HMC dio. The main theme will be the crew loading ammo and taking a break, so I'm not going to get too extensive on house accessories.
Brad
The rust is not really that bright, it's a photo thing. It's more subtile than it looks. I'm not sure why it looks that bright in the pictures. As far as a barrel, if you look in the first picture, in the upper left; you can see the barrel drying on a "pik-stick" after I washed and weathered it. I also have a wagon/cart wheel, stone well w/bucket and some other things that will be placed around the ruin.
This is my first attempt at a building, so my progress is slow on purpose.
Someday I will finish the whole project and it will be my first dio. Sometimes my learning curve seems tremendous.
I would appreciate more comments from others, I learn alot from everybodies help
Thanks again for you interest Claude and Brad
Claude
Brad
roudeleiw
Posted: Saturday, September 23, 2006 - 09:28 PM UTC
Dave,
Is your plaster on top of the stones (as it should be) or at the same level, that would be wrong ? It's a bit difficult to see on the picture.
You may also add some remainings of glass on the windows, always a nice touch.
For a first building, it's very well done!
Claude
Claude
Delta42
KitMaker: 616 posts
Armorama: 511 posts
Posted: Sunday, September 24, 2006 - 04:25 PM UTC
Claude
The stone and plaster are actually the same level. This is a Verlinden plaster kit. I have tried to scrape the stone work next to the plaster down just a little so as to give the appearance that the plaster is over the stone.
As far as more broken glass in the windows, that's planned, I just haven't done it yet. I also plan to add wiring to the exterior where it would come out of the building and then hang off of the connectors on the side of the building.
