James,
Two more things remain to be done...some black pastel applied to tone down the heavier collection of rust and then some Mig pigments for dust/dirt weathering as part of the whole running gear weathering process.
Building Tamiya's Char B1 bis
wbill76
KitMaker: 5,425 posts
Armorama: 4,659 posts
Posted: Tuesday, February 27, 2007 - 11:08 AM UTC
233350
KitMaker: 19 posts
Armorama: 18 posts
Posted: Tuesday, February 27, 2007 - 01:51 PM UTC
This is my first post her.
And I must say thath this tank looks very, very good.
But the main reson whay Im writing is because, Bill I like to asked you wich number is on this bottle of this MM Non-buffing Metalizer Gunmetal.
Thank you for vor respond to maj question.
Keep up the good work.
By
By
wbill76
Posted: Wednesday, February 28, 2007 - 12:54 AM UTC
Gregor,
According to the Testor's Catalogue, http://www.testors.com/catalog_browse.asp?ictNbr=40 it's Item # 1423. HTH and welcome to the forums!
233350
KitMaker: 19 posts
Armorama: 18 posts
Posted: Wednesday, February 28, 2007 - 01:03 AM UTC
Bill
Thank you very much for your answer. It is a big help for me
sportsguy64
KitMaker: 18 posts
Armorama: 18 posts
Posted: Wednesday, February 28, 2007 - 01:49 AM UTC
Nice work so far...yes, the tracks were a pleasant surprise and convenient depending on what kind of condition you want your vehicle in...easy to pull apart so pics of the front and rear sprockets can be taken.
What camo scheme are you going to use? Trust me, you will really enjoy the hand painting!
Charlie
Charlie
wbill76
Posted: Wednesday, February 28, 2007 - 08:06 AM UTC
Charlie![]()
Charlie,
No hand painting required..."Marne" had a soft edged two-tone green/yellow scheme which has already been applied by airbrush.
biffa
KitMaker: 881 posts
Armorama: 826 posts
Posted: Wednesday, February 28, 2007 - 08:34 AM UTC
looking really nice Bill great job, i took a screenie of a char online the other day to post for you i wasnt sure if you still check the game out or not
wbill76
Posted: Wednesday, February 28, 2007 - 10:27 AM UTC
looking really nice Bill great job, i took a screenie of a char online the other day to post for you i wasnt sure if you still check the game out or not![]()
It's been years (literally!) since I've seen the online incarnation, haven't been back into the beautiful fields of northern France in May 1940 for quite some time, last time was in 2002 or thereabouts. Send it on to me by email, would love to see how they look now given the advances that must have been made in the technology.
RichardM
KitMaker: 383 posts
Armorama: 358 posts
Posted: Thursday, March 01, 2007 - 06:32 AM UTC
Which magazine? I have the December issue of Tamiya Model Magazine, which features the "making of" the B1 Bis, and the Dec/Jan issue of Steel Masters with a diorama involving the model...
Sorry for the late reply.
Steel Masters #77 and #78
Histoire de Guerre Blindes & Materiel #74 One very interesting note is that that magazine will be exclusively devoted to French material from WW1 and WW2 starting with issue 74.
Bataille & Blindes #17 This is part 2 of a 3 parts article on the B1. I discovered that magazine with #17 and wasn't able to put my hands on #16
gluesniffer
KitMaker: 120 posts
Armorama: 89 posts
Posted: Friday, March 02, 2007 - 09:00 PM UTC
Very nice, Bill
Nice cammo and great step by step of the tracks
Great job
wbill76
Posted: Friday, March 02, 2007 - 10:41 PM UTC
Thanks Jim, appreciate the comments.
wbill76
Posted: Saturday, March 03, 2007 - 10:31 AM UTC
I started in with the weathering process today and what I thought would be a couple of hours turned into an entire day-long affair. There's a lot of surface area with the Char and it looks deceptively small but once I got started, I realized that the best way to approach it was in sections. I started with the hull sides first, then did the front half of the hull, followed by the turret, then the back half. Doing it this way kept me from feeling rushed and allowed each section to be done at its own pace. I'll use the right hull side to demonstrate the steps since they were followed in the same pattern for the whole vehicle.
The first step was to apply dots of Raw Sienna enamel across the entire camo scheme with a spotter brush. Once this had touch dried, I followed along with a 0 round brush and clean thinner and converted the dots into a filter coat over both camo colors. The Raw Sienna creates a nice earth tone tint as a filter and serves as the foundation for the rest of the weathering.
Once that had dried, I applied a similar spot pattern of Medium Green to the green sections only to allow for some variation in the green and to mix with the Raw Sienna applied earlier to the same end. These spots were blended in the same way, but needed a little bit more care to make sure they didn't spill over into the dark yellow areas. One of the advantages of applying this over a coat of Future is that it's very easy to clean up any mistakes with a Q-tip dampened with thinner or a brush for the harder to reach areas.
Next up was a pin wash applied with a 20/0 brush of 90/10 thinner/paint Burnt Umber enamel wash. Burnt Umber is a dark color that provides some good depth/shadow but I didn't want it to be too heavy and in some places it was necessary to come back after the thinner had dried and fine-tune it a bit to get the look I wanted. I also introduced some slight streaking in various places which will be combined with the Mig pigment treatment later on.
This same treatment was then applied to the rest of the vehicle.
As a final capstone to the day's activities, I went ahead and mounted the tow chains on the rear hull after it had been weathered. The kit instructions provide a step-by-step guide on how to drape the chains to get the desired look but only demonstrate one side...and of course, once one side is mounted, it's the second side that is more challenging to get right, but I managed after some fiddling back and forth. I'd painted the chain non-buffing Metalizer Gunmetal at the same time as I painted the track runs and they were given a Rust wash followed with Burnt Umber drybrushing and finally a Burnt Umber wash once mounted on the vehicle.
Not a whole lot remains to be done, essentially just applying a Dullcoat over the current setup and then giving it a Mig pigment treatment and mounting the tracks. Heading down the homestretch on this one.
Posted: Saturday, March 03, 2007 - 07:54 PM UTC
That looks great so far Bill,
The tracks look superb,I like these big plate types,nice and easy to weather,no fiddly little webs to try and get into.
I'm going to give your spot weathering a try ,looks good
following this post has inspired me to move mine to the "next" pile,as all my am goodies have turned up this week, Voyager pe,Lionmarc barrels,Blast models update and Archer decals,madness....
Keep them pics comming,look forward to seeing it finished
Andy
Andy
wbill76
Posted: Saturday, March 03, 2007 - 11:01 PM UTC
Thanks andy! Look forward to seeing what you do with yours with the AM stuff applied. The kit is a fun build with only some minor adjustments needed here and there depending. Any particular vehicle you have in mind?
Posted: Sunday, March 04, 2007 - 12:06 AM UTC
I want to do a tri colour cammo with the black outline,with some colourful markings,Lyon seems to fit the bill nicely..
http://perso.orange.fr/bm.img/page_galerie/gal39.htm
I do like a challenge!!!!
Andy
fatbobit
KitMaker: 164 posts
Armorama: 135 posts
Posted: Sunday, March 04, 2007 - 12:37 AM UTC
Hi Bill,
first of all congrats, you're doing a great job..! Im simply amazed. Your step by step process is really helpfull for me, under many aspects.
Also, im starting to focus my attention to a "strange tank" never considered before, probably due to my german-tank-guy mind ...! It seems to be a very nice "machine" to be builded.
Please keep us updated with your work , i cant wait to see your model finished.
Thanks again.
Ciao
Alex.
Thanks again.
Ciao
Alex.
wbill76
Posted: Sunday, March 04, 2007 - 03:16 AM UTC
Andy,
I'm sure you'll do it justice!
Alex,
Appreciate your comments, glad the step-by-step is helpful for you.
Alex,
wbill76
Posted: Sunday, March 04, 2007 - 07:09 AM UTC
Started off the final round this morning by giving the entire model a coat of Model Master Lusterless dullcoat in the rattlecan. I allowed this to sit for a couple of hours and cure up before beginning with the Mig powders.
I gave some thought to which combination of powders I would use for this one and finally settled on a two-tone approach using Dark Mud and Europe Dust. My reasoning was straightforward, France in late spring 1940 would likely have had both muddy and dusty conditions and the reference photos of different Chars seems to bear this out. I started out by applying the Dark Mud wet by brush all over the areas between the fenders and the sponsons, around the drive sprocket and mud scraper areas, and around the idler. Once this had air dried, I came back over the same areas with a smaller brush and spot applied the Dust over it so it would have a two tone-appearance vs. mixing them together and applying as one application.
Once all that was dried, I took a round stiff bristled brush and worked the two colors together while removing excess pigment at the same time.
As a last step, I took a q-tip and mositened one end and alternated with the dry end, blended and worked the effect more around the bolt heads and to create some streaks/runs from where mud/dust would have been scraped off and run down the sides. A side effect of using the q-tip is that it also buffs/fixes the pigments into the finish, a combination I think of the fine pigment powder and the "tooth" of the dullcoat finish, but the end result is it can be handled, with care, without any additinal fixative needed.
This process was repeated on the other side and the hull front and rear. I wasn't too sure how best to go about handling the hull top and turret, it kept bothering me especially in contrast to the weathered hull sides. The green in particular seemed too clean vs. the rest of the vehicle, so I opted to apply a thinned down water-based wash of the Europe Dust and let it air dry to create a thin film of dust. Once dried, it was also adjusted with the stiff bristled brushes and q-tip where needed.
In the course of all this, I'd also applied a wet coat of Europe Dust to both tracks and allowed them to airdry so it was now time to install them. This was a bit of a puzzle at first, since both the vehicle and the tracks were weathered, I wasn't quite sure how best to handle them for installation. After a couple of unsuccessful attempts with tweezers, I opted to remove the sprockets and use the old "rubberband" track method. The tracks were connected at the ends and looped over the idler, adjusted into place over the top skids and the roadwheels, then the sprocket set in the end of the tracks and carefully maneuvered back onto its mount post. The tracks runs are a tight fit, but the Tamiya grommet design for the sprockets made this the best option for installation. I also installed the clear lens for the auxiliary headlamp that was converted from a Pzkpw I-B leftover set in the spares bin.
One final adjustment was made in the form of some light drybrushing of Steel to the track faces and work was done.
Then it was off to the photo booth for the finished shots.
More to come in the feature article.
AikinutNY
KitMaker: 683 posts
Armorama: 630 posts
Posted: Sunday, March 04, 2007 - 08:20 AM UTC
Truely awesome work on that model. I hope that my work turns out half as good as your.
wbill76
Posted: Sunday, March 04, 2007 - 07:30 PM UTC
Thanks Jim, I look forward to seeing you bring "Fantasque" to life, be sure to post pics along the way.
Bleak
KitMaker: 26 posts
Armorama: 26 posts
Posted: Monday, March 05, 2007 - 07:14 PM UTC
These tracks are outstanding ! great job !
wbill76
Posted: Monday, March 05, 2007 - 08:09 PM UTC
Thanks Bleak, appreciate the comments.
233350
KitMaker: 19 posts
Armorama: 18 posts
Posted: Monday, March 05, 2007 - 11:41 PM UTC
Hi!
This is fantastic tank and you did a fantastic job Bill
Gregor
Gregor
wbill76
Posted: Tuesday, March 06, 2007 - 02:06 AM UTC
Thanks gregor, much appreciated.
mark197205
KitMaker: 1,593 posts
Armorama: 1,465 posts
Posted: Tuesday, March 06, 2007 - 04:41 AM UTC
Am very glad to see this finished Bill, it looks a real beauty, am definitely gonna get my hands on one of these very soon, as soon as the campaign stuff i've commited to is finished anyway, Flammpanzer Char1Bis here I come....
ps, shall be looking out for the feature and having a thorough read for bits you kept back...
