Des,
Nice model you have going there. Can't say I like all the B&W photos. I prefer a bit of color, but that's just a personal preference! I'll echo what Roy said earlier about the seam between the curved and vertical surfaces of the fenders. Next time perhaps seal that join with some superglue using baking soda as a kicker. That will leave you a solid sandable join line. Also, the four recesses found on the back plate should be filled, or at least covered in mud to hide, I think. They were designed by Dragon to locate the spare link boxes I believe, and would not be applicable to T66 track. In their place should be threaded steel squares.
Otherwise, super job!
Mike
Thank you Mike. I wasn't sure whether the recesses should have been there or not but thinking about it I see your point.
I have to adjust a few things with the lower hull so the seems on the fenders, the recesses and the speed numbers can get added.
I will get some colour photos on here too. I just get carried away with the B/W as I think it adds atmoshere and authenticity.
Thank you all again for the kind comments.
Des
