I'm closing in on the paintjob on this one soon. Just gotta get all the yankee stash loaded on to the rear of this Sherman. Not a big fan of that but I think it's needed on Shermans.
Finished the fender supports and turret. Brushed and stippled some Mr. Surfacer 1000 for some structure on the turret.
Here's a few pics...
I banged up the front fender supports a bit to go with the miss-aligned and banged up fenders. On the left side I removed the front support completely. I drilled a hole in the fender where the bolt should have been, and added a small PE bit on the hull to simulate the broken mounting point.
On the right side I bent the bracket and added another small PE bit on the hull to simulate the broken mounting point on that side.
Inside the commanders cupola a standard M6 PE periscope was mounted. I used some small plastic tubing cut in half to simulate the pivot points on the periscope. The hatch shutter mechanism consisted of three parts that where quite fun putting togheter. In addition to that I drilled and hinged the hatch to make it moveable, I think this look better too
In the rear of the turret I fabricated the missing foundry symbol of letters shaved from a piece of sprue. I also added a weld seam to the .050 transport bracket(?), and I added another small tie-down.
.050 barrel bracket...
Some turret details in the next two pics...
Loaders hatch and periscope detail. I made the hatch springs because the molded on ones didn't look very nice.
Here's the hook that holds the loaders hatch down while in open position.
I tried to simulate the cast seams on the turret with Mr. Surfacer. One of the seams can be seen below the turret lift ring.
I've noticed something typical on the pistol ports of the Sherman on all pics I've seen, it's a kind of "punch mark". Usually we remove these marks when building, but I added this one on purpose with Mr. Surfacer and an aluminum tube. :wink:
Last detail shot is the gunners periscope and the commanders vane sight. (I think that's what it's called)
And finally some "full figure" shots so far.
I can't wait to start painting this one...
Constructive Feedback
Sherman M4A3 105mm HVSS ** WIP **
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Thursday, June 19, 2008 - 01:00 PM UTC
liberator
Luzon, Philippines
KitMaker: 1,086 posts
Armorama: 783 posts
Armorama: 783 posts
Posted: Thursday, June 19, 2008 - 02:01 PM UTC
wow...loaded with details...! will you be using the dragon (DS) tracks? can't wait to see how you'll fix the loosen tracks. i'm still staring at my sherman figuring out how to remedy that. nice build and thanks for sharing.
HONEYCUT
Victoria, Australia
KitMaker: 4,002 posts
Armorama: 2,947 posts
Posted: Thursday, June 19, 2008 - 10:33 PM UTC
Gday Per-Erik
Some fine work is continuing here!
One thing though is the commander's fixed periscope. I think it should be set a little lower and further back in the armoured cover, not flush with the opening. Maybe lower it so the screwed frame is level with the turret top, and suspend it so it is roughly centred in the hole through to the turret interior.
One other thing is the periscope flap on the commanders cupola. It sits too high as it is solid! Try and match the folded Aber versions as they are hollowed as per the real things, and sit much better over the periscopes. Also, there should be a holder attached top the inside horizontal support for the headlight guards.
It is a cylinder shaped tube which a small screw cap gets fastened to whent he headlights are installed. Other wise, it screws into the headlight socket, attached to the tube with a small chain. You can see it next to the outside of the centre Canadian's right ankle...
Seems a shame to overspray it in the end mate!
Brad
Brad
sgtreef
Oklahoma, United States
KitMaker: 6,043 posts
Armorama: 4,347 posts
Posted: Sunday, June 22, 2008 - 01:46 PM UTC
Well Per-Erik you have made me drool long enough I am getting one also.
So thanks Buddy.
Looking great I might add don't know if I will add as many parts though.
So thanks Buddy.
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Tuesday, June 24, 2008 - 12:19 AM UTC
@Jeff: Thanx bud! Now stop drooling and go out and get that Sherman.
@Brad: Thanx for the kid words om my build, mate!
I followed your advise and repositioned the periscope farther in and lower, in the armored cover. I also made the tubes for the headlight socket covers with the chains.
I'm reworking the Aber part for the commanders periscope too.
I've also started to work on the stash and the Browning .050.
Some pics...
The Periscope...
The covers...
The stash I'm planning to add...
The Browning parts...
Later...
Gday Per-Erik
Brad
Some pics...
The Periscope...
The covers...
Later...
HONEYCUT
Victoria, Australia
Posted: Tuesday, June 24, 2008 - 03:34 AM UTC
Nice work Per-Erik. Looking really good mate. Problem with your close ups is that it reveals more and more things you could do to enhance the kit
The foul weather hood attachment strip (The curve around the bow .30mg) is actually a separate steel tube which is tack welded on. Easy enough to reproduce with scale wire and some careful shaping! (If you wanted to...) The one thing that will prove most difficult is the small pins that the hood itself attaches to...
Brad
Brad
Belt_Fed
KitMaker: 1,388 posts
Armorama: 1,325 posts
Posted: Tuesday, June 24, 2008 - 03:48 AM UTC
I have no idea how you guys work with PE. That stuff just drives me crazy. What often happens is i either drop it on the floor or the super glue bods at the wrong time or doesnt stick at all. I normally just say "screw it" and forget about it. Superb build, cant wait to see it painted.
210cav
KitMaker: 6,149 posts
Armorama: 4,573 posts
Posted: Tuesday, June 24, 2008 - 04:37 AM UTC
Jon-- do not think you are the lone ranger with PE. It drives me up a wall, but on those rare occasions when I do not glue my fingers together and actually get the part on the tank--it looks good! Keep tryin'
DJ
skyhawk
KitMaker: 1,095 posts
Armorama: 743 posts
Armorama: 743 posts
Posted: Wednesday, June 25, 2008 - 02:42 PM UTC
outstanding work!! you really did a great job on the PE stuff from A-BEAR. Ive been adding the same set to my Thunderbolt VII kit, and havent tackled the stowage bin yet. One thing i was wondering...did you glue the bogies on the hull yet? I thought from dry fitting the bogies myself that I discovered that i would be unable to get the rubber tires on the inside rims if they were attached to the hull...can you confirm this? (my memory is a bit rusty, and im a few hundered miles from my workbench right now.
looking great, cant wait to see it painted!
Andy
Andy
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Thursday, June 26, 2008 - 11:16 PM UTC
@Brad: Thanx again Brad! I'll see what I'll do with the attachment strip, but as for now I have a feeling I'll leave it as is, wanna start painting soon...
Thanx for the cudos, appreciate it!
You remember correctly regarding the bogies, and yes I have glued them. It is possible to mount the rubber tires after the bogies are glued in place, it is a tight fit but it is doable, thou I wouldn't recommend it. Kinda glued them on in a weak moment...
Andy
sgtreef
Posted: Sunday, June 29, 2008 - 11:44 PM UTC
Okay my friend.
A question for you.
How the heck are you going to get those tracks on there???
Not meant to be rude.
And are you going to use the kit ones.
I have the kit now Per-Eric and also the AFV Club T-80 tracks but the pins on them are weak and there are two marks that must be sanded off on each link.
So let me know okay.
Thanks
A question for you.
Thanks
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Monday, June 30, 2008 - 12:50 AM UTC
Okay my friend.
A question for you.
Thanks
No offense taken, bud!
I'm planning to use the kit supplied tracks, cause I think they look quite good, and mount them in a kinda "tread and pull" fashion and glue them togheter with Tamiya Thin Cement when mounted. Then I'll just mount the rear idler and tighten them with that in place.
Makes sense?
sgtreef
Posted: Monday, June 30, 2008 - 12:54 PM UTC
Quoted TextOkay my friend.
A question for you.
Thanks
Makes sense?
Sure does Dude.
I was wondering .
think I might do it a little different taking an easy way I think.
But will be by Christmas until I get that far.
Still a great job and can't wait to see the paint going on.
Are you ,okay no more questions.
skyhawk
Armorama: 743 posts
Armorama: 743 posts
Posted: Friday, July 04, 2008 - 08:15 AM UTC
[quoteYou remember correctly regarding the bogies, and yes I have glued them. It is possible to mount the rubber tires after the bogies are glued in place, it is a tight fit but it is doable, thou I wouldn't recommend it. Kinda glued them on in a weak moment... [/quote]
yeah, i know what you mean...i have been VERY tempted to glue mine on to see how it looked. I did end up temp gluing them on with white glue (Sobo glue, as its more rubbery than elmers, and easy to remove from plastic), that way i could paint them while they were on the tank, and remove them to get the tires on, then reattach permanently.
your lucky you have the DS tracks in this kit (which i think look awesome...i which they would market some track seperate). Ive used the AFV club tracks in the past, and they take a long time....and lots of adult beverage!
I want to get one of these kits...i would just have to find a correct mantlet and the DML one is a bit off.
looking forward to more pics!
Andy
Andy
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Sunday, July 06, 2008 - 01:12 AM UTC
Phew!
The Browning finally done!
32 parts in all on this one was a challenge itself to get togheter, quite a bit of soldering I tell you 8O , but I'm quite happy with the result if I may say so.
It'll be exiting to get some paint on this one too. The ammo belt is just put down in the box for "illustrational purposes only". I gave it a coat of white glue for some volume, but I'll recon I'll give a coat or two more before painting.
Here's some pics from all angles and more...
sgtreef
Posted: Sunday, July 06, 2008 - 01:17 AM UTC
Great job on that Ma duce.
Amazes me how you glued that stuff together.
I know I have about 4 of these part sets that I look at , and put in the storage bin for another year or time.
Never.
More Pics Dude.
Never.
More Pics Dude.
sgtreef
Posted: Wednesday, July 09, 2008 - 10:32 PM UTC
A bump and how is this Sherman coming along?
210cav
Posted: Thursday, July 10, 2008 - 02:48 AM UTC
Jon-- your M-2 Browning is outstanding! Very nice detail. Well done
DJ
DJ
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Thursday, July 10, 2008 - 06:24 AM UTC
@ Jeff: Thanx for the cudos on the M2, dude! It was a real p.i.t.a. to put togheter but I pulled it off.
The progress is slow these days due to really hot weather up here in Norway so I'm mostly outdoors.
I'll post some new pics once the bad weather sets in...and it will I'll tell ya!
@DJ: Thanx for the kind words on my Browning effort.
Later, Per-Erik
Later, Per-Erik
sgtreef
Posted: Thursday, July 10, 2008 - 09:21 PM UTC
Glad to see you enjoying the weather.
I guess it can wait.
CaptainA
Indiana, United States
KitMaker: 3,117 posts
Armorama: 564 posts
Armorama: 564 posts
Posted: Sunday, July 13, 2008 - 01:29 AM UTC
Nice clean work with great attention to detail. Very effective use of PE.
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Monday, July 14, 2008 - 05:46 AM UTC
@Carl: Thanx, glad you like my work.
Checking refs isn't always a good thing when you want to finish a model in a timely fashion.
I'm officially not certifyable anymore, I'm adding casting numbers!
Dragon was kind enough to include some of the numbers molded to the kit, but a ref check revealed that more of them was needed.
Here's some of the numbers I've added so far, and according to my refs there will be more. But, detailing kits are fun...
I front of the gun shield...
On the turret top...
sgtreef
Posted: Monday, July 14, 2008 - 01:36 PM UTC
You must be committed soon.
Nice job and watch for the men in white coats.
Really looks good,sweet deal.
Archer I guess?
So how are those tracks coming along ?
Waiting to see them.
Archer I guess?
PvtMutt
Missouri, United States
KitMaker: 614 posts
Armorama: 601 posts
KitMaker: 614 posts
Armorama: 601 posts
Posted: Monday, July 14, 2008 - 02:09 PM UTC
Holy Smokes, that's impressive.
...Mutt...
...Mutt...
Stampede
Østfold, Norway
KitMaker: 109 posts
Armorama: 107 posts
KitMaker: 109 posts
Armorama: 107 posts
Posted: Wednesday, July 16, 2008 - 11:55 AM UTC
@Jeff: I'm looking over my shoulder every minute...
Yup, those are Archers. I guess I'll start painting the tracks this weekend.
@Tony: Thanx!
Here's the last addition of casting numbers on the inside of the drivers hatch. I copied these from a ref pic I got from Brad. Thanx mate!
Now I GOTTA get down to painting this thing soon!
@Tony: Thanx!
