Armor/AFV: British Armor
Discuss all types of British Armor of all eras.
SUPACAT ATMP
ArnoRiedel
Netherlands
KitMaker: 20 posts
Armorama: 19 posts
Posted: Monday, August 08, 2011 - 07:04 PM UTC
A picture I took at the War & Peace Show
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Tuesday, August 09, 2011 - 08:29 AM UTC
That is so cool Arno.
PM send.
jon_a_its
KitMaker: 1,336 posts
Armorama: 1,137 posts
Posted: Tuesday, August 09, 2011 - 08:56 PM UTC
Great progress so far...
(still want one, btw, )
amagno
Sao Paulo, Brazil
KitMaker: 6 posts
Armorama: 4 posts
Posted: Monday, September 05, 2011 - 03:33 PM UTC
Outstanding work !! Please put me in your list for one limited run kit, i want one! Let me know if there is a pre-order list. Thanks.
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Sunday, December 25, 2011 - 12:22 PM UTC
I have to re-do the whole build as I'm not satisfied with the first one. Issues with shape and small disproportions in numbers. I have managed to do another master for casting of this project.
This time everything looks in scale and I'm happy with it. This will be my first version. The back roll cage is just a trial fit. I have to turned the head light manually to re-create this part and one of the difficult things to do. All roll cage is temporarily attached to maximise accuracy before casting it.
This is the final master before casting. Most of the main parts have been done whats left are small details and tiny parts. Stay tune.
Here you can see the old chassis I made.
A full walkaround of the build, 80% complete.
Trisaw
KitMaker: 4,105 posts
Armorama: 2,492 posts
Posted: Sunday, December 25, 2011 - 12:56 PM UTC
That looks really neat! I'd be interested in one.
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Sunday, December 25, 2011 - 11:38 PM UTC
Thanks Peter!
Just keep track of the thread. I will update from time to time.
Karl187
#284
KitMaker: 3,094 posts
Armorama: 2,942 posts
Posted: Monday, December 26, 2011 - 01:12 AM UTC
Great to see more progress on this, outstanding!
BLACKWATER
Yunnan, China / 简体
KitMaker: 449 posts
Armorama: 441 posts
Posted: Monday, December 26, 2011 - 02:09 AM UTC
Hi val
I can imagine how it is difficult production process, which requires skill and perseverance. Thanks to share.
I have become your fans.
WJ
Trisaw
Posted: Monday, December 26, 2011 - 06:29 AM UTC
Are you going to make it like Arno's photo?
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Monday, December 26, 2011 - 08:06 AM UTC
I will do this version also which is fitted with WMIK.
17741907
Istanbul, Turkey / Türkçe
KitMaker: 953 posts
Armorama: 705 posts
Posted: Monday, December 26, 2011 - 10:56 AM UTC
Looks great Val...Seems will be done this time...Good luck...
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Tuesday, January 03, 2012 - 09:50 AM UTC
Thanks guys!
HunterCottage
#116
Stockholm, Sweden
KitMaker: 1,717 posts
Armorama: 629 posts
Posted: Wednesday, January 04, 2012 - 02:42 AM UTC
What exactly about the tires makes them left- and right specific??
Great work!! There is just something about tires... I could model only tires... that and engines... okay I'm off my rocker
HunterCottage
#116
Stockholm, Sweden
Armorama: 629 posts
Posted: Wednesday, January 04, 2012 - 03:49 AM UTC
They say that the first thing you go blind in is your eyes... never mind answering, I see what is rotation dependent now...
BTW did I say that this is awesome work!!!
HunterCottage
#116
Stockholm, Sweden
Armorama: 629 posts
Posted: Thursday, January 05, 2012 - 03:41 AM UTC
Yes its me again!!
On Supacat's homepage it states that the ATMP has 31/15.5 R 16 tires, but most everyplace else shows 31/15.5 R 15??
Have they changed dimensions maybe??
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Thursday, January 05, 2012 - 07:12 AM UTC
Hello Brian, There are several marks of ATMP. I Think ALVIS produce the mark III which is what I'm doing. Very few info on this and if you look closely rims vary too. I'm doing the 15 inch rims. There are other thread pattern also. If you look closely the sides of the one im doing is a bit thicker and had an opening panels both rear and front in which the signal lights are attached. You can also see a slight difference on the gauge panel. The engine is by VW ADE 1.9 turbocharged diesel. I think the older mark has a different engine but I'm not sure about this.
Spiderfrommars
Milano, Italy
KitMaker: 3,845 posts
Armorama: 3,543 posts
Posted: Thursday, January 05, 2012 - 07:42 AM UTC
It looks simply excellent.
Great job!
If you want and don't mind, it would be great if you wrote a tutorial about "how to scratch build wheels". Yours are perfect !
I think lot of us (of course, included me) would like to know how they can manage to do it exactly
Anyway, congrats indeed
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Thursday, January 05, 2012 - 08:12 AM UTC
Thanks Mauro. I have a few pictures on this but if you take a look at the begining of the thread I have explained how I did the wheels. To recap, this is made from a laminated styrene sheet to appropriate thickness then turned to correct diameter then slowly shaped to exact size. Then sanded smooth after which thread pattern is added individually. Hope that helps.
Spiderfrommars
Milano, Italy
Posted: Thursday, January 05, 2012 - 08:50 AM UTC
Yes, it helps, thanks a lot
Only a pair of questions
Did you used a lathe or a drill to shape them?
How did you make the tread? Did you cut every single part of your pattern?
I'm interested in Russian subjects, and wheels usually are quite ugly in the kits of Russian subjects
For exemple I'd like to make the wheels for my trumpeter MAZ 537 or for my EE Gaz-66, but I haven't done it yet
thanks in advance for your replies
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Friday, January 06, 2012 - 07:31 AM UTC
I used a variable speed drill and dremel for fine tuning. A lathe would be the best but I have no space in my house even for a small one. Thread pattern is made from evergreen styrene cut to precise lenght and placed individually. This takes a lot of time but if you do it really slow you will end up with a more precise alignment. I think the shape and turning is the easy part, the thread pattern is more challenging. With bigger Soviet tyres I think it would be ok.
Spiderfrommars
Milano, Italy
Posted: Friday, January 06, 2012 - 11:07 AM UTC
Thanks a million, when I have a little time I give it a try for sure
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Sunday, September 02, 2012 - 12:40 PM UTC
Reviving this thread. Its been a long time since I last upated this (busy w/ work & family).
8 months on and still on a slow progress but managed to get most of the small details sorted out.
Here are series of pictures showing the rivets, drive system, exhaust,engine deck, intakes, rear door, rear lights and under chassis detailing.
Still needs the full winch, console, shifter etc....
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Sunday, September 02, 2012 - 12:47 PM UTC
I have temporarily taken down the roll cage for ease of work. Here you can see the wheels dry fitted and set to the correct distance. The ATMP utilizes a front four steering mehanism and slide skid to turn.
Notice the steering bar and how it should looked (off set).
I still have a long way to go and a lot of details to be added. Once done I could start casting and make several versions.
Keef1648
South Carolina, United States
KitMaker: 1,240 posts
Armorama: 1,192 posts
Posted: Monday, September 03, 2012 - 04:44 AM UTC
Brilliant, absolutely brilliant. My hat is off to you Sir.
Put me down on the list for ome as well.
Keith.
