Armor/AFV: Braille Scale
Canadian Leo 2 A6M
sauceman
KitMaker: 2,672 posts
Armorama: 2,475 posts
Posted: Tuesday, March 13, 2012 - 02:26 AM UTC
Amazing work at this scale.
cheers
SchoeniR6
Germany
KitMaker: 189 posts
Armorama: 189 posts
Posted: Thursday, March 15, 2012 - 02:11 AM UTC
Hi
Great work aon the Leo.
I like all the details. Looks very fine.
Cheers Daniel
gcdavidson
KitMaker: 1,698 posts
Armorama: 1,563 posts
Posted: Thursday, March 15, 2012 - 10:00 AM UTC
like a fine Swiss watch
Panther64
#261
KitMaker: 395 posts
Armorama: 365 posts
Posted: Saturday, March 17, 2012 - 12:29 AM UTC
Val, you're going to need a vacation after this little build! Or a trip to the asylum! Simply fantastic, can't wait to see it finished!
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Saturday, March 17, 2012 - 06:21 AM UTC
Thanks a lot gents!
Kerry, Im over the edge with this!
Braille
#135
KitMaker: 1,501 posts
Armorama: 1,485 posts
Posted: Saturday, March 17, 2012 - 10:21 AM UTC
@r2d2 – Val,
I know it’s been a while since your last post and this one but do take your time and work when you feel highly motivated, as you are doing a magnificent job!
~ Eddy
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Monday, March 19, 2012 - 11:44 AM UTC
Thanks fellas!
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Monday, March 19, 2012 - 11:55 AM UTC
I have managed to do the hull's left side slat armours. Aligning the whole assembly is a nightmare. Distance on the first 3 slats is 5.9mm in 72nd and the rest is 4.8mm. This has to be pricise as it will not look good if its off. The right first 3 main slats was in place but got to lazy to do the remaining armours plus the back. I will update evrything once fully done but for the meantime here are some detailed shots of the brackets, spacing and even the bolt heads.
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Monday, March 19, 2012 - 11:58 AM UTC
Here are some shots of how it looks with the turret. Still a long way to go but i'm getting there.
sauceman
Posted: Monday, March 19, 2012 - 12:06 PM UTC
Looking great!
Are the comms boxes, C-8 bin and glacis up armour included in the kit?
cheers
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Monday, March 19, 2012 - 12:27 PM UTC
Thanks Richard! All the white styrene you see are scratchbuilt. Basically the kit is the plane ol Leo 2 A6M and this is a full new mould including the belly armour. All the Canadian version you see here is my conversion.
Firefly74
KitMaker: 224 posts
Armorama: 205 posts
Posted: Monday, March 19, 2012 - 06:21 PM UTC
Very impressive! Looking forward to seeing more.
Tim
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Tuesday, March 20, 2012 - 07:11 AM UTC
Much appreciated Tim!
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Friday, March 30, 2012 - 10:05 PM UTC
Construction is almost done minus all arials. Conversion for this Canadian version are all scratchbuilt. No details are compromise including bolt heads on the slats support brace. I have hallowed out both head lights in prep for the lens. Details are also added in the coms box, main gun cooling vents, all arial was turned, optics detailed and opened. Side mirrors redone in stowed position and cables replaced by scratchbuilding fine wires. I added a bit of drama to the lower hull slats by bending it producing wear and use because this are prone to damage in the field.
I will apply a thin primer and proceed to painting this next.
Picture heavy with lots of detailed shots.
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Friday, March 30, 2012 - 10:08 PM UTC
More pictures.
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Friday, March 30, 2012 - 10:11 PM UTC
More....
Next is full painting and weathering....
Citizinsane
KitMaker: 463 posts
Armorama: 450 posts
Posted: Friday, March 30, 2012 - 10:54 PM UTC
absolutely outstanding...
been following the build and gotta say I'm truly amazed...
makes me want to build one of these right away...
Cheers, Max
sauceman
Posted: Friday, March 30, 2012 - 11:45 PM UTC
Simply amazing, can't say that enough.
cheers
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Saturday, March 31, 2012 - 02:08 AM UTC
Thanks Rick,Max. Will update after priming so that details can be seen clearly.
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Saturday, March 31, 2012 - 05:40 AM UTC
Finished the primer stage. Couple of pics showing the details of this build.
r2d2
KitMaker: 424 posts
Armorama: 419 posts
Posted: Sunday, April 01, 2012 - 09:02 AM UTC
Updates: Sculpted the first few stowage from Milliput.
This is how it looks on the tank. Will add some more once I have the extra time.
recceboy
KitMaker: 706 posts
Armorama: 665 posts
Posted: Sunday, April 01, 2012 - 09:30 AM UTC
Val
Job well done, keep us posted.
Anthony
sauceman
Posted: Sunday, April 01, 2012 - 10:01 AM UTC
Nice work on the stowage!
cheers
terminators
France
KitMaker: 1,932 posts
Armorama: 1,907 posts
Posted: Sunday, April 01, 2012 - 01:37 PM UTC
Very accurate work, you are a very good modeler ! You have much more patience than me.
Did you use a magnifying glass to build the slat armor ?
Won't you put a MCS barracuda ?
Braille
#135
Posted: Sunday, April 01, 2012 - 04:03 PM UTC
@r2d2 - Val,
That actually looks like a 35th scale build! SWEET!!!
~ Eddy
