Dioramas: Campaigns
Group builds and online competetions. Join the fun!
RMG:Envarīs "Eagle has landed" -progress
Envar
Uusimaa, Finland
KitMaker: 1,088 posts
Posted: Sunday, February 01, 2004 - 08:29 PM UTC
Friends,
RMG campaign finally showing some advance!
My British para took a life of its own when I saw a nice pic showing a guy with an open chute. I had to scratchbuild the harnesses and the jacket on the basic Dragon figure (thanks for the ref links guys!) and it came out really nice. I wasnīt too picky about every single strap but it should be ok.
Hereīs the reference pic with the first in progress shot of the figure. I took the pic with my Nokia 3200 mobile phone, better pics will follow! Iīll also make a descrption of the technique I used to make the parachute. You guessed right: kitchen foil again!
Iīm still going for black&white colouring with this...
Toni
zer0_co0l
Limburg, Netherlands
KitMaker: 1,432 posts
Posted: Sunday, February 01, 2004 - 09:00 PM UTC
wow toni thats just great.
really nice done!
very good I like it
cant wait to see the finished result.
maybe you can make a feature about making a chute?
Envar
Uusimaa, Finland
Posted: Sunday, February 01, 2004 - 09:06 PM UTC
Envarīs Excerpt is in the making as we speak!
Toni
Major_Goose
Kikladhes, Greece / Ελλάδα
KitMaker: 6,871 posts
Armorama: 2,071 posts
Posted: Sunday, February 01, 2004 - 09:16 PM UTC
Looking impressive plan, but at first site checking the pic and the figure i think the chute is a lil small.have u done scaling in dimensions to find out the size to make it? I am very curious to see it going cause it is something i have been thinking but never tried ,go gogo my friend
Envar
Uusimaa, Finland
Posted: Sunday, February 01, 2004 - 09:37 PM UTC
Thatīs right, it is way too small, almost 1:35 scale as my figure is 1:16 scale...
In this case itīs a matter of practicality, I have had no intention making a base that would be half a meter long to make the ropes and parachute proportions correct. I may fold the parachute down thus braking the round shape so that the dimensions wouldnīt become an issue.
I admit that I never do any accurate scaling in dimensions, this Parachute v1.0 was just a test if the technique would work; it did, but the dimensions got wrong.
Thanks for pointing that out. I have to think about this a bit more.
Maybe a very narrow, long base wouldnīt be too bad after all... :-)
/EDIT/
Like this, perhaps?
/EDIT/
Thanks,
Toni
slodder
KitMaker: 11,718 posts
Armorama: 7,138 posts
Posted: Sunday, February 01, 2004 - 11:37 PM UTC
Wow - another one!
Here's an idea (depending on what your lines are made of) have the chute extend out in 'space' off the base and scale it up a bit. Suspend the chute using stiff wire for the lines and shorten the base a bit (long wise, make it more square). That would definitely give it a dramatic affect.
Great idea and I'm looking forward to the excerpt! :-)
Eagle
Noord-Brabant, Netherlands
KitMaker: 4,082 posts
Armorama: 1,993 posts
Posted: Monday, February 02, 2004 - 12:12 AM UTC
Jummy Jummy,
Eagle loves these developments ! No need to worry guys... I know Toni pulls it off again.... We're in to see another awesome dio soon again.....one of the very few dios with a parachute....excellent that someone has the nerve to try it !!!
GeneralFailure
European Union
KitMaker: 2,289 posts
Armorama: 1,231 posts
Posted: Monday, February 02, 2004 - 12:24 AM UTC
Toni,
- the figure is absolutely smashing. It doesn't look a bit stiff (like most model paratroopers do) but it's very much alive and in motion. A true Envar figure !
- the chute IS very small. Maybe you need to give that some thought after all...
- when a shute is "blown up" by the wind, there's a typical flower-shape with nice round lobes between each two ropes. The Black/white picture nicely illustrates this. The model shute doesn't reflect this : its "wrinkles" are erratic. This looks nice, but it doesn't look as real as it could. I can imagine the technical problems to make a chute like that. The idea of making a mold springs to mind. Wouldn't it be possible to model/sculpt a parachute shape out of some solid material, and then mold the paper chute using this shape ?
This would probably be a very painstaking and messy trial, without guarantee for success, so I probably would discard the idea even if I would have to make a parachute. I just wanted to share the idea... I'm curious to read how you made this shute. Probably also by using a molding shape of some kind ?
Jan
Plasticbattle
#003
Donegal, Ireland
KitMaker: 9,763 posts
Armorama: 7,444 posts
Posted: Monday, February 02, 2004 - 12:28 AM UTC
Looking great Toni. A very ambitious project. Another method for using the 1/16 figure and a 1/35 scale parachute is use a forced perspective dio. Basically everything gets smaller as it goes to the back of the dio. I think Iīll leave you to work out how to do that ... Im getting a sore head! #:-) Good luck with this ...
shonen_red
Metro Manila, Philippines
KitMaker: 5,762 posts
Armorama: 2,283 posts
Posted: Monday, February 02, 2004 - 12:32 AM UTC
Whew! Looking good! Standing by for the final shots....
Envar
Uusimaa, Finland
Posted: Monday, February 02, 2004 - 12:47 AM UTC
Thanks boys,
yes this is a tricky thing to do...
I used metal wire bent to flower shape as the skeleton of the parachute. It was then covered with kitchen plastic and it has grey primer on it. You can actually shape the parachute any way you want and it holds, except when itīs compeletely round. I think Iīll have to use thicker wire for the body...
This technique works very well if the parachute is at least a little bit folded.
Thanks again,
Toni
Graywolf
Staff MemberSenior Editor
HISTORICUS FORMA
Izmir, Turkey / Türkįe
KitMaker: 6,405 posts
Armorama: 1,850 posts
Posted: Monday, February 02, 2004 - 01:27 AM UTC
very good idea and very good job Toni. please keep us posted for every step on that.
PorkChop
Wisconsin, United States
KitMaker: 3,179 posts
Armorama: 1 posts
Posted: Monday, February 02, 2004 - 04:33 AM UTC
Envar:
Sweet conversion. Perhaps a shadow box can help you with the forced perspective/scale issue. In any case that's a great idea, it'll be intersting to see the final product. Yet another winner from Envar.
What's the ETA on completion?
ShermiesRule
Michigan, United States
KitMaker: 5,409 posts
Armorama: 3,777 posts
Posted: Monday, February 02, 2004 - 04:46 AM UTC
That's a great idea. I love it. I like slodder's idea of using a small base and the chute off the base.
Envar
Uusimaa, Finland
Posted: Monday, February 02, 2004 - 09:24 PM UTC
Iīd say at least a couple of weeks.
After solving the technical problems thereīs still the painting part. Trying out black & white the first time, I donīt expect it to go without problems...
I like the idea of rigging the parachute off the ground, just havenīt solved the construction of the parachute. I could use a few hard steel wires as strings, but Iīm still not sure if that would be enough to support the cupola...
I tested it yesterday and the farther from the figure, the smaller the parachute can be.
Toni
GeneralFailure
European Union
Posted: Monday, February 02, 2004 - 09:32 PM UTC
Toni,
here's an alternative idea for the strings : try simple sewing thread.
You stretch a strand of sewing thread between two fixed objects to keep it straight, then impregnate it with CA glue.
The result looks stiff as a steel wire, but thinner and with more thread-like texture. It's a very simple procedure, and it works well.
When cut to size, these stiffened threads can easily be mounted to your parachure using CA glue.
Be careful though : when you apply CA glue to thread or cloth, it tends to immediately release fumes. (there must be a chemical or physical process that provoques this). Watch out for your eyes !
Envar
Uusimaa, Finland
Posted: Tuesday, February 03, 2004 - 02:15 AM UTC
Jan,
I was about to go for fishing line to make the strings. Iīm just still trying to figure how I could make those strings strong enough to hold the weight of the parachute all by themselves...
Anyone know where to get thin wire made of Adamantium(tm)? #:-)
Adamantium is a virtually indestructible man-made steel alloy which does not occur in nature and whose exact chemical composition is a United States government classified secret. Adamantium is not an element: its properties do not qualify it for any know space on the Periodic Table of Elements. Rather, Adamantium is a series of closely related compounds of iron created through a secret process discovered by the American metallurgist Dr. Myron MacLain.
-www.marveldirectory.com
Toni
kkeefe
Massachusetts, United States
KitMaker: 1,416 posts
Posted: Tuesday, February 03, 2004 - 07:33 AM UTC
Toni,
Once again, your talents are just incredible!
If it would help, perhaps your trooper could be using his reserve chute... this is smaller in diameter and has shorter risers than the main parachute, but not always worn depending on the jump altitude. I do not know what the jump altitude was for "Market Garden". Just a possibility, but in all actuality, in those days, if the main malfunctioned and you went to your reserve, the main's harness etc would still be attached to you. Today's main chute can be released prior to deploying the reserve to avoid any entanglements.
I can't wait to see this one finished!!
Eagle
Posted: Tuesday, February 03, 2004 - 09:04 AM UTC
I can tell from the figure that it is a British Paratrooper and....the British Para's didn't wear reserve chutes. The Americans did, so the idea is valid. Only make a US Paratrooper to go with it..
zer0_co0l
Posted: Tuesday, February 03, 2004 - 09:11 AM UTC
hiya. I read here that the us troopers didnt wear the reserve chutes during market garden.
it was a low level jump, so no reserve chutes were worn.
atleast thats what I read.
Eagle
Posted: Tuesday, February 03, 2004 - 09:21 AM UTC
Low level or not....the US did wear their reserve chutes in the Market Garden Drops :
zer0_co0l
Posted: Tuesday, February 03, 2004 - 09:47 AM UTC
then I was misinformed and misread my humble appologies
Eagle
Posted: Tuesday, February 03, 2004 - 09:55 AM UTC
Hey Ho,
let's lighten up.... I didn't mean to play the schoolteacher If it sounded that way , then I am sorry ! It wasn't my intention at all.
Don't feel bad about it Juul, not all the books are 100% accurate.....and.... I gave you info on some troopers who DID wear their reserve chutes, perhaps there where units that DIDN"T wear them at all.
So don't feel bad about it. I'm sorry if I sounded like the good old teacher
zer0_co0l
Posted: Tuesday, February 03, 2004 - 10:00 AM UTC
no biggy danny
no offence taken etc etc
Eagle
Posted: Tuesday, February 03, 2004 - 10:01 AM UTC
Well,
Juul and I have been "thinking" on the MSN Messenger....perhaps there actually where US units that didn't wear reserve chutes in Market Garden....does anybody know if this can be true...or even better...wich units didnt wear them ??
