Armor/AFV: Contests
southpier
KitMaker: 546 posts
Armorama: 316 posts
Posted: Wednesday, May 15, 2019 - 10:47 PM UTC
... Pf.11 was hauled . . .
thank you; educational video
165thspc
#521
Kentucky, United States
KitMaker: 9,465 posts
Armorama: 8,695 posts
Posted: Thursday, May 16, 2019 - 01:47 AM UTC
Great build Angel on the Ponton and trailer. Also thanks for showing me the proper contour shape for the K-Garet deck planking. I thought as much but your work confirmed it!
Mike
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 1,432 posts
Armorama: 1,390 posts
Posted: Thursday, May 16, 2019 - 02:46 AM UTC
Thanks Mike!
And you're welcome
Although the available width in K-Geraet bridge was bigger than in B-Geraet bridge(3500 vs 3200 mm), still it is possible that both Geraete used the same size of cover planks(Belagbretter).
The cover planks used in Type B bridge had following dimensions in mm(L-W-H):3840-260-47.
Short explanation for the role of the 4 end cutouts in Type B Bridge planks:
Once the planks were laid, the cutouts provided enough space for the body of the tightening clamp:
Once tightened, the clamp pressed the fixing beam(running above the planks) to the longitudinal beams(running bellow the planks, mounted on the walls of the halfpontoon).
A clamp-being installed and tightened-can be seen at 07:16-07:19 in the video I posted earlier today.
HTH,
165thspc
#521
Posted: Thursday, May 16, 2019 - 03:32 AM UTC
Very informative German film!
165thspc
#521
Posted: Friday, May 17, 2019 - 01:43 AM UTC
The K-Gerat roadway structure appears to have had a very substantial (8 inch x 8 inch) lengthwise "curb" beam placed on each side of the roadway on top of the crossways wooden paving planks. Whether the C-clamps then retained just the curb beam or still acted upon the individual planks I cannot say.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Friday, May 17, 2019 - 02:18 AM UTC
Mike,
If there were commonalities in the construction of B and K type bridges, then the retaining C-clamp should act both on the "curb" beam and on the longitudinal beams, thus sandwiching the paving planks between them.
165thspc
#521
Posted: Friday, May 17, 2019 - 07:57 AM UTC
I know there is some sort of slot cut in each end of the curb beams and the vertical handrail support upright comes up through this slot.
On the larger K- bridge system the vertical support carries a rope "handrail" rather than a horizontal pipe as in the smaller bridge.
Dioramartin
New South Wales, Australia
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Friday, May 17, 2019 - 05:06 PM UTC
Jaw-dropping scratch-work Angel, the woodwork looks perfect. Hope you’ve checked that pontoon for leaks
(PS hi Mike thanks for your message way back maybe in this forum, yes Susie's turning cartwheels again)
ayovtshev
#490
Sofiya, Bulgaria
Posted: Friday, May 17, 2019 - 05:18 PM UTC
Thanks Tim!
Uhhh- I haven't done that leak check, my omission...
Will perform one and dully report back!
ayovtshev
#490
Sofiya, Bulgaria
Posted: Friday, May 17, 2019 - 05:27 PM UTC
Mike,
You might have these K-Gerät photos:
Don at Voronezh 1942
Germany 1939-1940:
I don't see any clamps...
BTW, there is a big collection of trophy German documents in Russia, that is scanned and available online:
http://www.germandocsinrussia.org/de/nodes/1-russisch-deutsches-projekt-zur-digitalisierung-deutscher-dokumente-in-den-archiven-der-russischen-foderation
I found some info on the B type there and will check again for K type related documents.
PeterMax
Bayern, Germany
KitMaker: 81 posts
Armorama: 74 posts
Posted: Sunday, May 19, 2019 - 03:47 AM UTC
Hi ajovtshev,
Referring to your Pontonwagen (which really is an astonishing work); you wrote that apart from the resin tires it is 100% scratch build. Now, I would like to know, which tires have you used for this trailer project?
Peter
ayovtshev
#490
Sofiya, Bulgaria
Posted: Sunday, May 19, 2019 - 04:18 AM UTC
Thanks Peter!
To your question-I used PanzerArt's KHD 3000S Road wheels Commercial pattern(#35-352).
They are rather big and I had to compensate for their height in order to keep the overall height of the loading platform.
Actually-I should have used the Opel Blitz 2,5-3,2 tyres(Dnepromodel offers them), as they fit the sizes of Pf.10-12 tyres almost perfectly, but lacked enough time to wait for an order.
Next time I'll use Dnepromodel tyres for sure,
HTH,
PeterMax
Bayern, Germany
KitMaker: 81 posts
Armorama: 74 posts
Posted: Monday, May 20, 2019 - 02:33 AM UTC
Thank you for your quick and detailed answer!
Peter
165thspc
#521
Posted: Monday, May 20, 2019 - 02:37 AM UTC
Thanks Angel - I too had the same question regarding the source of the tires and had wondered about the possible use of Blitz resin tires as well.
Thanks
ayovtshev
#490
Sofiya, Bulgaria
Posted: Thursday, May 30, 2019 - 07:42 AM UTC
Peter and Mike,
2 days ago I received 60+ pictures of a Pf.11 Pontonwagen, exhibited(!!!) in the Museum of Engineer Units in Svishtov,Bulgaria.
The tires of the trailer are Bulgarian, but the wheels are original.
The inscription of the tires(32x6-Д) reflects Bulgarian State Standard and corresponds to tire size 6,5x20:
I further checked the sizes for a 6,5x20 tire in the "Technisches Handbuch fuer Fahrzeugluftreifen-1939" and found that the width of a twin 6,5x20 wheel corresponds to the width given for the Pf.11 twin wheels in the Lone Sentry database:
Thus the right tire sizes for all Pf.10/11/12/13 trailers are:
Or in 35th scale-tire height of approx. 24 mm, single tire width of approx. 4,5 mm. while twin wheels width should be 10,5-10,6 mm.
HTH
petbat
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Friday, May 31, 2019 - 10:35 AM UTC
All together now - "Angel is a rivet counter"....
Your research into your subjects is as awe inspiring as your modelling work.
I really have to get to Bulgaria and see all this equipment before someone decides to sell it...…
165thspc
#521
Posted: Friday, May 31, 2019 - 11:07 AM UTC
Angel
Many thanks for the additional K-Gerät photos!
One shows exactly a detail point I was after!
Mike
ayovtshev
#490
Sofiya, Bulgaria
Posted: Saturday, June 01, 2019 - 07:27 AM UTC
You're welcome, Mike!
Peter,
I think this Pf.11 will never be sold- it is stored in an active military base and one needs permission from the CO to enter the ground.
I was also told, that the Pf- and all other vehicles/equipment stored and displayed there- is/are part of the inventory of the National Museum of Military History in Sofia.
If you decide to visit my country-let me know.
I'll organize some rivet-counting for you
petbat
Posted: Saturday, June 01, 2019 - 07:55 AM UTC
Fantastic Angel. I'll come prepared.
PeterMax
Bayern, Germany
KitMaker: 81 posts
Armorama: 74 posts
Posted: Sunday, June 02, 2019 - 03:42 AM UTC
Hi ajovtshev,
I just have read your explanations about the tires of the Pf11.
Thanks again for this helpful information.
Peter
